Picture tutorial on Installing Trackspec Motorsports C6 vented hood extractor louvers
#81
We have used a jigsaw in the past and can tell you that a harbor freight 9.99$ cutoff wheel with a 5$ pack of thin cut metal blades cuts thru like butter! With that set up, the holes can be cut very quickly and straight.
I'm sure others have used a jigsaw or other methods but that's the most effective way we have found after doing tons of installs.
Any standard autozone or Home Depot matte black paint can be used to paint the edges. Not a necessary step, but as Matt and others have shown, it really cleans up the install for a factory finish.
Thank you all for your support!
#82
CONE RACER (07-09-2016)
#83
I used my dependable HF angle grinder with their cut off wheel. As the instructions say, it is best to cut no more than 1/8" outside the lines. I stayed inside, but had to do a lot of trimming and filing. I went ahead and spray painted mine, as it would be hard to do once installed. There was a lot of white showing from the cutting, so I wanted to cover that up. I also used my dremel and a drill to remove some of the underneath hood that would get in the way of installing the washer for the rivets. The rivet thing is really a 2 man job, or in my case, a one man/one 11 yr old daughter job. She is experienced in the rivet gun now! Good luck with it.
#84
vents
does anybody know how much do the center vents stick out into the engine bay - how deep they go into the engine...i have an eforce and i think they might hit the top cover of the SC..
#85
#86
Installed the Trackspec kit today. Nice product, well packaged, and instructions are easy to follow. Hood was off the car, but a friend of mine installed his with the hood on. One thing I did was to cover the hood first with some shelving liner. This made it much more comfortable with incidental contacts on the painted surface of the hood.
I located the louvers per the instructions. Pictures in this thread seem to show the louvers mounted in different locations, but the camera angle can make it look very different. You can see by the two pictures of mine taken from two different angles.
victorf (07-09-2016)
#87
Appears yours and another member made the center louver hole behind hoods brace?
Do you have under hood installed pictures to show louver's layout?
One member responded my PM and I appreciated that!
I am committed and ordered a set of unpainted louvers - there is a wait to hold off a set of unpainted in the next production run. Maybe I should ask John direct for the instruction while I am waiting!
Tia!
#88
The brace is cut during installation per the Trackspec dimensions. Cutting the brace and putting in the louvers did not seem to affect the rigidity of the hood. For reference, the center section sits (approx) 13 inches back from the front of the hood. The side louvers sit (approx) 20 inches back from the front and about 3.5 inches off to the side of the center section. Don't over think it too much. It's not too hard of an install and Trackspec has done all the research / math for you to get it in the best spot for performance.
With a bit of an interstate test drive today I saw 10 - 15 degree water temp drop. Oil temp was about normal. Ambient air today during my drive was about 92 degrees, so I was pleased to see the water temp down in those conditions. I expect the lower water temp to help with lowering the oil temp under track conditions.
victorf (07-10-2016)
#90
Looking this over I'm very interested to see if this would work with a E force supercharger installed. Currently my supercharger leave a impression in the hood liner as well as the throttle body.
I'm looking for some help in reducing engine and oil temps during my track events.
#91
BigMonkey73 (09-08-2017)
#92
Track Speck hood vents work with aftermarket lingenfelter sv3 hood?
Hi guys,
Does anyone know if these vents would work with a
lingenfelter SV3 magnusson supercharger hood (I have a tvs2300 supercharger on my ls3 motor)?
I would love to be able to use these vents with my hood to help cooling of my supercharged motor and additional downforce.
Here is a link to lingenfelter’s website for the hood –
http://www.lingenfelter.com/product/L850080105.html
#93
I know that the C6Z has some issues with lift at high speed so I understand that the vented hood helps with that along with heat. But I haven't seen much information regarding the narrow body C6 bottom breathers. Does the vent provide the same benefits to heat dissipation and lift?
I live in central Texas and as a lot of people know it gets hot as all get out during most of the year. I am mildly concerned with heat during track events when I do get the chance to get out there. While only marginally concerned with lift (my home track isn't big enough for speed much over 90mph).
#94
#95
lift
My radiator coolant temps on track are consistent now for 20 minute sessions since hot air now flows through the radiator and out the center vent, rather than getting trapped then sucked out the bottom of the car. On track I noticed a 5 deg drop on coolant and oil cools down a lot faster when it gets hot. Before the vents, coolant was a bit more inconsistent and the oil took forever to cool off on cool down laps.
Regarding lift, I heard that closer to 140 or 150 mph it's more of an issue, and even then it is more of a slight "floaty" feel in the front suspension versus feeling more planted with the vents. I haven't noticed the difference in front end feel (only a few tracks I run allow 150 on the straight and even then it's only for a few seconds), but I have noticed it helps keep the coolant consistent.
In traffic in Florida with ac on it seems to help. Still gets hot with ac blasting (coolant 220 - 225F at stoplights when 95+ outside) but the fan blows the air right out the hood instead of it getting trapped. And once I start moving, the coolant temp drops very fast back to 210 or so. Before the hood vents were installed coolant on a similar day would get to 235F and took longer to cool once I got moving.
Hope that info is useful
#96
Does anyone know if these vents will clear with an MSD intake installed on my Z06? Also has anyone tried to install the fender vents, if so could you post pictures I'm curious to see if holes are cut in the wheel wells with the fender vents.
