C4 rear wheel bearing recommendations: Thread?
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Been using the search function but haven't found a helpful thread yet with recommendations on a decent, robust brand of rear wheel bearing that will hold up to some decent amount of track days. I've got a C4 suspension under my '69, and I just noticed the LR wheel has a bit more play in it than I'm comfortable with. If you can point me to a helpful thread (or offer up some past experience with particular brands) I would be grateful.
Thanks!
Thanks!
Thanks!
Thanks!
Just not much support for a car that's been out of production for 18 years.
You might call someone like LG or LPE. Never know if they have something laying around.
Another alternative is to source good used hubs. I think part of the problem we have with new hubs is putting them on and not having enough low stress mileage to break them in before tracking or autocrossing.
Thanks!
Thanks!
They just were never engineered for long duration track duty. With a full-up race car or even the old Corvette Challenge days, all you needed was a day out of them. During most of the C4s life-span, track days and R-compound tires were not nearly as prevalent as today.
For awhile, one of the posters on here had a stock of hubs from Tommy Morrison. Supposedly they were filled with better grease and would last a little longer.
As someone else mentioned, early/mid '90s F-body hubs work as well. You need to drill out the mounting holes or use bolts to mount them. Other than that they're identical....and about half the price.
Received 1,741 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I tried the break-in routine....500 miles of a variety of street driving. No change in life span of the hubs with sticky tires.
P.S. They dont last any longer either, just slightly cheaper.
ALL C4 hubs are junk. I have just as much life out of the cheap china ones as I did Timken, SKF, National, etc.
The Camaro hubs fit the FRONT of a C4. The camaro ones are taped and not a through hole for mounting though. You either drill them out for the stock C4 bolts, or use the slightly smaller Camaro bolts.
I consider hubs on C4's to be expendable like brake pads. If you run a C4, you gotta pay to play just like anyone else. I buy the Moog ones from Advance for a reason. 3 year warranty. They don't ask questions, so I don't tell.
Have you ever considered using a tire like the Kumho XS? Less sticky but better wear and easier on the hubs.
