Removed AC on C5, what are you using to seal between the radiator and plastic shroud?
Like the title states, I no longer have AC in my c5z. The OEM condenser had a foam strips on it that sealed against the plastic shroud. Now that the AC condenser is gone, what do you recommend using to seal the radiator against the shroud?
ABS plastic to seal off the gap to the radiator after removal of AC condensor.
hmhaga (10-28-2020)
