C5/C6 control arm interchange
All,
I haven't seen any definitive information on what C6 control arms are a direct bolt-on for the C5 chassis. Does anyone know for sure what arms fit? I've seen a lot of speculation that the front upper and lower arms are drop-in replacements (from narrow-body C6s only?), but don't know if anyone has actually done the conversion. I know that the rear lower arms aren't a direct swap since the C6 is "spring-over" and the C5 is "spring-under", but don't know anything about the upper arms from the narrow-body cars.
Any insight will be appreciated.
edit: I guess we could add C7 to this, since the layout is similar.
