Broken Pfadt front sway
So as you can see in the pictures, the arm that extends from the bar to the end links has snapped. Good thing i decided to take a look....
When i bought this car from the previous owner the arm was welded together, so this was a weak point to begin with. Running at Road America didnt help it either.
My question is this: since this is a pfadt front sway, and pfadt is no longer in business; what are my options?
The rear sway is a pfadt also but that one is fine. Couldnt I just replace the front with something else? or do both front and rear have to be the same?
I don't think you need a matched set. If you like the rear bar then get a front bar from elsewhere, stiffer or less stiff depending on if you want any change to the car. 2 cents.
I think I can get you a contact for getting another set of those arms.
e-Mail me, oli at Alvaka.net, and I will get you hooked up.
Imho I would not waste the money on fixing them. I too had lever arm issues with the Pfadt sway bars, it's kind of a known issue. I have never seen them break before though, Normally because the splined section is machined at an angle the force applied to it when the car rolls causes the splined section to deform which results in the tightened down lever arm simply sliding off. So you will be going around a corner and suddenly the lever arm will just fall off! That happened twice to me before it just got wedged under the lower control arm and completely ripped off and tossed onto the track after which I promptly switched to LG bars. Save your self the potential grief and get something that is designed right those things are an accident waiting to happen.
This was one of Pfadt's "fail" products. And no the brand does not have to match f/r. Just buy a new bar that suits you/the car
The last thing I would do is try to find another.
Thank you everyone. I might just order up some new LG G1 front and rear sways and call it a day. No reason in fixing a part that looks like it will just fail again.
I have not had any problems with mine, but I am ordering a pair of spares as I like to have as much spare everything as I can. There is nothing worse than driving across the country for a race and breaking a part in qualifying two hours before the big race.
I have had mine for well over a year with no problems. Just this year I have more than twenty races and numerous track/test & tune days without any issues.
I like them for their increased stiffness, lightness and adjustability compared to my prior T1 bars.
Those arms were most likely typical billet stock which has a hardness of T6, but after welding you get basically "0" temper which is about half as strong. Never should have been welded in the first place, as noted, those bars are an accident waiting to happen.
I know of 3 other people that had Pfadt sway arms break like this...and I had issues with a previous set of Pfadt bars on my car. Got a set of the "newer" light rate bars a few years back and have not had a problem with them....yet.
*I really liked the Pfadt products because they give great adjustability...but damn...something about their quality control and response to hard duties just makes them a bad choice for anyone who is very serious about tracking.
Former Vendor
There's nothing wrong with aluminum, but you have to respect that the fatigue limit is really pretty low. That is, if you have it in a situation where there is reversed stress, you can't put stress in it up near yield, like you can with steel, or it will fail in fatigue. A high strength tempered spring steel is worth over 120 ksi, and aluminum in this case should be stressed to about a tenth of that.
Watching how much that bar was flexing, it's no wonder that it broke right where it did, that's the obvious high stress location and right where the stress is concentrated by the radius, but I don't think you could add enough material to make that work without doubling the thickness of the part. This is an area where a steel part is probably the way to go.
