Wheel Well Vents, instaled
Finally got around to installing my wheel well vents. I thought I'd share the finished product and listen to comments, good or bad. I might learn something.
Decided to stick in a pic of the new splitter struts as well
I thought the idea of the side vents was to evacuate air from the engine compartment.
Have considered removing the plastic piece on the side vent to get more air flow past the dry-sump tank?
You may want to make tunnels to channel the air and keep debris from collecting, however you may also want to vent the hood to get more hot air out of the engine bay if you do this
one of the first "mods" (if youd call it that) I did on my base c6
The wheel well builds up a high pressure area causing some front end lift. And the air is dirty air as it exits the wheel well. I'm hoping this will release the air easier and cleaner. CFD study's of the wheel well area show the venting helps.
Also, I removed the front air dam in front of the tires. I hope that will reduce the amount of air being pulled/packed into the wheel well. I am making ducts going to the factory brake cooling duct to make up for removing the dam as the dam is just behind the duct opening. I'm sure I lost some air flow and velocity into the brake cooling duct by taking the air dam off.
Everything is an experiment.
I have a hood waiting to get the vents. That will be a next spring addition.
The base of the windshield is a high pressure area that will fill your engine compartment with air.
If you install a vent in the hood in the forward areas you will get evacuation of under hood air.
Look at the race car for an idea on placement.
have you tried removing the rear valence and trimming hte rear liners to fit? this should vent more air out from the rear...
If i'm wrong, please help out.
Yes and no, that's why I only removed the two sides. The middle section is still in place. The c6z is a front feeder radiator set up. The air that goes through the radiator enters through the grill. The air dam adds air to the engine compartment that enters behind the radiator, not through the front of the radiator. So I don't think the air going into the engine compartment because of the air dam actually goes through the radiator.
Again, correct me if I'm wrong.
Envision the area behind the air dam as a low pressure area and "pulling" air down and through the radiator.
Either way, it is a moot point if you left the center section in place.
The air damn is supposed to prevent more air from spilling under the car, thereby reducing aerodynamic drag and rear end lift, however, because of its placement, it creates a high pressure zone which causes front end lift.
If you can evacuate more air out the rear it might be a good idea to remove the entire airdam. Also if you can at least cover the subframes with flat sections, this will also help reduce drag and lift that the airdam is supposed to help prevent.
EDIT:
AHHH bad memory!
Hows the project going?
EDIT:
It was going good until I blew up the brand new engine. The car sat in the shop of 75 day, (the whole freaking summer) I have it back now and decided not to work on it until the fall. IT and the new hood should be ready by spring.
The volume of air on the top of the hood is much greater and it has a higher velocity. Under the hood is lower pressure.
IIRC there were some pictures of C6s at the nurburgring showing how much air pressure builds up - so much so that the hood gets pushed upward. There is a german company that actually makes a device that attaches to the hood latching mechanism in order to raise the hood and allow air to escape...
EDIT:
Found it:
http://dev.tikt.de/wp/?page_id=225
EDIT:
Found it:
Originally Posted by TIKT
HAUBE
TIKT Performance Hauben Halter für Corvette C6
Diese optische Leckerbissen, verfolgen einen recht einfachen wie simplen Grundgedanken, sie sorgen dafür, das durch die aufgestellte Haube
die heiße Luft im Motorraum austreten kann. Die Halter sind binnen weniger Sekunden ohne schmutzige Finger anzubringen und genauso schnell
wieder abgebaut! Wasser und Öltemperatur wird um ca. 10C° gesenkt, aber der eigentliche Vorteil liegt darin, das die Nebenaggregate wie Lichtmaschine, Anlasser, Hauptbremszylinder im weiteren Verlauf
auch die Kupplungs Glocke, das Tourqe Tube bis hin zum Getriebe, weniger von der sich anstaunenden Motorhitze angegriffen werden, klar dass das in allen Bereichen nur von Vorteil ist.
Die Halter wurden von uns bis 300km/h getestet, trotzdem sind sie nicht im Straßenverkehr zugelassen und nur auf abgesperrten Strecken zu benutzen!
Preis: € 230,- inkl. 19% Mwst. zzgl. Versand
HOOD
TIKT Performance Hood holder for Corvette C6
This visual treat, follow a fairly simple and simple basic idea, they ensure that by the posted hood
the hot air to escape from the engine compartment. The holder shall be installed within a few seconds without dirty finger and just as quickly
broken down again! Water and oil temperature is lowered to about 10C °, but the real advantage is that the accessories such as alternator, starter, brake master cylinder in the further course
also the clutch bell, the Tourqe Tube and gear units are less affected by the engine heat up anstaunenden clear that this is in all areas of advantage only.
The holders have been tested by us to 300km / h, but they are not allowed on the roads and to use only on closed!
Price: € 230, - incl. 19% VAT. plus. Shipping
Very nice! I like how all that wheel well area is used up. Thats one area of my design that I might change after testing.
Fast moving air is low pressure, sloww moving air is high pressure (generally) Bernouli's rule.
The hood/windshield has the venturi effect.
In the pic all the blue is low pressure
