Where to get a camber kit
Old 09-14-2014, 08:58 PM
bb69
bb69's Avatar
Default Where to get a camber kit
Do any of the vendors make a camber kit? Pfadt is out of business and Hardbar's site is still down. I need the rear camber kit to eliminate my "active" suspension.
Ken
Old 09-14-2014, 11:16 PM
sperkins
sperkins's Avatar
Ken
I can make you a kit if you can't find one - or just for the rear if that's all you want.
Old 09-14-2014, 11:20 PM
5280Racer
5280Racer's Avatar
Vansteel
Old 09-14-2014, 11:39 PM
blkbrd69
blkbrd69's Avatar
http://www.vansteel.com/index.cfm?fu...subgroup=32030
Old 09-16-2014, 11:58 PM
REVHARD
REVHARD's Avatar
PM me a price for front on a C5
Old 09-17-2014, 11:35 AM
63Corvette
63Corvette's Avatar
Front and rear for my C5Z
Old 09-17-2014, 07:17 PM
braknl8
braknl8's Avatar
I have these...can't beat 'em. Better buy up before he runs out of stock again.
Old 09-17-2014, 07:46 PM
StKnoWhere
StKnoWhere's Avatar
Wow, why so much hardware?
Old 09-18-2014, 08:37 AM
hklvette
hklvette's Avatar
For the VanSteel kit? The "washers" at the center of the picture are probably the upper arm shims.
Old 09-18-2014, 01:12 PM
el es tu
el es tu's Avatar
Yep; however if youre set on it, you can buy shims like the pfadt ones from mcmaster carr...
http://www.mcmaster.com/#standard-shims/
Old 09-18-2014, 02:35 PM
sperkins
sperkins's Avatar
Sorry for the late response guys. I haven't checked the thread lately.
Full kit is $175
Front only is $120
Rear only is $60
I have enough material left to do 5 full kits.
Old 09-18-2014, 07:55 PM
morris
morris's Avatar
Ken
I bought a camber kit from LG Motorsports this spring even had them install it for me. Very satisfied with the setup and install
Old 09-27-2016, 01:07 PM
63Corvette
63Corvette's Avatar
How much for the kit and install?
Old 09-27-2016, 02:54 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I should have kits in stock, just need to know if it is a steel frame car or alum.
Anthony
Old 09-27-2016, 03:15 PM
AKKutz
AKKutz's Avatar
Anthony
Will these kits work on the C7?
Old 09-28-2016, 12:58 PM
YYZ06
YYZ06's Avatar
The Pfadt kit is available through aFe Power.
http://afepower.com/afe-power-450-40...ame-camber-kit
Old 09-28-2016, 01:23 PM
64drvr
64drvr's Avatar
Received 1,866 Likes on 886 Posts
St. Jude Donor '15
Anthony
Price on the kit please.
To Where to get a camber kit
Old 09-28-2016, 03:30 PM
froggy47
froggy47's Avatar
Full kit is $175
Front only is $120
Rear only is $60
Good deal guys.
I would suggest the front upper studs to replace the bolts also, makes it so easy. Not sure if it's in this kit, sperkins will let you know. Shims are just a few bucks at McMaster Carr.
Old 09-28-2016, 05:02 PM
Sox-Fan
Sox-Fan's Avatar
I ran Scott's kits on my C5. really good guy to deal with and very responsive when someone (hello ridetech) throws a wierd curve at you.
I'll be buying another set for my c6 when I get it ready.
sperkins (10-27-2016)
Old 09-29-2016, 06:07 PM
Rx7Rob
Rx7Rob's Avatar
What range (and increment) of adjustment do the various kits provide using just the LOWER plates (front and rear)?
Vansteel
LG
aFe / Pfadt
sperkins
StreetSpeed
Rob
Quick Reply: Where to get a camber kit
