Back on Track after 2 Years: Lots of Questions!
Hey Gang!
Long story, boring - but I finally got to race the '99 FRC again after 2 years. Bought a set of Hoosier A6's for the occasion and took 3.4 seconds off my previous best time by the end of the weekend. Qualified 6th in all 4 races, and finished 6th/5th respectively on Sunday with a DNF & DNS on Saturday. All was not lost.
So, the DNF/DNS was a result of the thermostat sticking closed and me pulling out of the first race due to coolant overtemp (had been fighting for 3rd after a first lap mele when I had to start backing off), couldn't run the second race & spent the time fixing the car. New T-stat, rad cap & coolant from the local auto parts store (thank you Lordco, for being right by the track) and I was idling at 205F for 30 min on Saturday evening and ready to go for Sunday.
Set my best time in Sunday first practice (running two run groups this weekend, for a total of 2 hrs per day track time, so no real time to cool down - me or the car). By the time the first race was half way over (was firmly in 6th at the end of a 6 car chain, big gap to 7th) I had to start backing off to manage the temp - no leaks or issues, just not enough cooling capacity. Second race I took that into consideration and had the heater cranked, and after the first couple laps where I was established firmly in 5th, I started short shifting & lifting in the corners - more concentrating on maintaining speed in the corners than top end and held my position easily to the end of the race. I've never had a cooling issue before, but I was doing 120 mph at the end of the front stretch compared to 105 with my old tires, so I guess I just hit the point where I was now making more heat and the cooling system couldn't handle it.
So, the first question: new radiator. I've got the DRM 'race' stand alone oil cooler installed and am thinking of their Ron Davis 'non-coolers T1 legal' rad. Or perhaps one from DeWitts. I like the idea of upgrading the fans, and want to wire in a switch to keep them on in the paddock.
Thoughts & comments?
Hey Gang!
now as to the fan Darn thing draws 30 amps so you can't leave it on long with out the engine running
If that's what racers do?
With an elec. waterpump, I get that but that's even MORE on the batt.
Maybe you hook up aux batteries?
I do not know all that much I guess on cooling systems, but what would be the point of running the fans to cool the radiator coolant only (without the engine running)?
Get the DeWitts radiator from Summit Racing. It is at least twice as thick as the OEM radiator and drops in place. It fixed my coolant temp issues at NASA Nats three weeks ago. I have a huge oil cooler, no AC, extra ducting, splitter, no shroud Spal fan, etc and was hitting 237 and managing 232-234. Installed the bigger DeWitts from Summit Friday night and never saw above 210 in the Saturday race and the Sunday Champ race despite running the car as hard as possible in high 90 degree air temps. Track temps were well over 100.
-Kevin
-Kevin
-Kevin
-Kevin
Thoughts?
Do you ever have issues with the PS overheating? If so, the typical fix for that is Redline fluid and a cold level barely on the stick. The fix after that is a Turn One pump.
Either way, I personally prefer to have separated systems. Makes it easier to swap a broken part at the track.
I think I'll go with the DeWitt's rad & Spal fans. If I don't do it before the next race (it should be a lot cooler in mid Oct), I might expand the scope of the job to include diff & tranny coolers. If I remember correctly, there are kits that tie into the Z06 rear brake cooling ducts - so I'd have to install those as well!
On a race track, your PS fluid is going to heat and expand regardless. The lower cold fill level allows the expansion to NOT spew out of the cap, onto your headers, your tires, and your windshield when you are battling for the lead at 140mph.
-Kevin
-Kevin
What were your peak oils temps during race? What are the dimensions of your oil cooler and is it in front or behind radiator? I've seen some C5's at NASA events with the oil cooler behind the radiator. Wouldn't think it would help much with super heated air from the rad going through it but would help coolant temps not having it in front of the rad.
Thanks.
Rob,
As for the oil cooler, I will need to take some measurements, but it is MUCH larger than most. PCM of NC used my car as a prototype and they can sell you the kit if you want them to bundle one together for you.
We went with the oil cooler in front of the radiator for ease of packaging. There is more room in front than behind and it makes for an easier, universal mounting approach with the brackets. The other reason is oil temps are usually more critical than coolant temps. Meaning, oil temps are the first thing to start rising before you start having coolant temps... In the experiences of most of us.
Before the oil cooler, I could hit 307* oil temps in two laps while coolant temps stayed lower for longer. After the oil cooler, my oil temps stay in the 230-250 range depending on time of year. They are stable enough that I never monitor them anymore, I only watch coolant temps. At some point, I need to put gauges for each in the car.
On the question of combined systems or not, I am a proponent of separated systems for reliability and each of changing. I have had to change radiators at the track due to track debris and if I had combined systems it would have been messier and more complicated. Keeping them separated is just another assurance in reliability for me in that damage to one cooler does not affect two cooling systems.
-Kevin
-Kevin
I have seen on a friends G8 supercharged car a custom res/cap from some Aussie race parts company (IIRC). Drops in on an LS motor.
Maybe something there to check out.
If it's permissible for your class, you might consider a different hood. I know a couple guys that are supercharged and swapping to a vented hood did the trick regarding the various temps since much more air will flow through the radiator and engine compartment.
Rob,
-Kevin
-Kevin
What do you mean by a "no shroud Spal fan"? I was thinking of using the setup from DeWitts: -> link
We completely re-designed our C5 fan package to utilize a lazer cut aluminum shroud. The shroud incorporates (4) four rubber flapper valves to improve air flow at high speeds and close at slower speeds. Two Spal 12" high performance fan provide 3200 cfm, which doubles the factory output.
Thoughts?
Rob,
-Kevin
-Kevin
Would love to see photos and get size of the oil cooler you had done to get those great results.
I have this tread about oil coolers if you would like to post them there.
If you dont want to post them, PM me for email.
https://www.corvetteforum.com/forums...iscussion.html
Thank you.
Thoughts?
Thoughts?
If this is not a 100% street car with AC and whatnot, you don't need a shroud. A shroud funnels air through the radiator and though the fan when the fan is running while you are idling or barely moving. AT SPEED, the fans turn off at 35mph and now the shroud becomes a blockage to free air flow through the radiator. Anything other than a bare fan is going to block air flow while on track.
I went with a single Spal 16" pull fan mounted to the back of the radiator and wired into the OEM harness. After seeing how much air it pulls and verifying that it keeps my coolant dead on the thermostat setting at idle, I am certain a smaller 14" would do just fine.
Really appreciate your input!
