C5: Street Touring Unlimited (STU) Build Thread
#61
Any hints as to what spring rate to start with? Springs are next on my purchase list.
I got a response from VBP about testing against stock springs, he said about C5 1997 - 2004 "These varied from around 600 to 725 pounds per inch on our machine. The standard C-6 front springs we tested came our even less, at around 420 pounds per inch."
Looks like they measure high, about 150lbs.
I am currently on the path of HPT front spring/ Z06 rear spring until I find a reason that won't work. Strano 33mm front bar, Z06 rear bar. If the HPT front spring makes for too much % front TLLTD I can still go up to a Strano 25.4mm rear bar or a HPS rear spring.
Lane, do you think pitch oscillations will really be a problem with those fancy MCS shocks you have? Plus isn't the ride rate already higher in the front than the rear, even with stock springs? Rear spring rate is higher but the motion ratio is worse afaik.
#62
Supporting Vendor
#63
Supporting Vendor
Largely personal taste. I carry a number of shocks. The Koni's, MCS, Ridetech which are made by Fox (and someone I trust says the valving is good but I've never run them), KW (and you can run the KW's without coil-overs on a car with leaf springs but it's kind of a pain. Hard to beat a Koni to be honest. I can even get Penske's, but I don't tend to since I've been so pleased with the MCS stuff in the high end arena (no leaks, etc.).
#64
#65
Make sure you are looking at natural frequency, not wheel rate. I'm talking about having a higher rear frequency than the front, not necessarily rate.
The delta in frequencies is mainly aimed at preventing ride oscillations like I mentioned and as far as I know, pretty much all cars come with this split from the factory. You design the rear ride frequency slightly higher than the front because the front will encounter bumps first. Having the rear frequency higher results in the car settling out to ride oscillations instead of pitch. Pitch oscillations tend to cause more issues like motion sickness, but can also mess with things like the ABS under braking.
#66
Based on my conversation with Sam, I think this is the best start for everyone that wants an STU C5, except maybe add the Strano 25mm rear bar. Extra suspension adjustment is always good on these things, especially since the rear suspension is so easily accessible in grid.
#67
What makes you choose HPT over VBP? The claimed rates are all over the map so it's hard to figure out what the actual difference is between the two (or 4 I guess, each manufacturer has 2 options).
I'm seeing these as the only options on the market:
VBP 97310 "775-875" rate http://www.vbandp.com/auto-parts.htm...category_id=59
VBP 97320 "900-1225" rate http://www.vbandp.com/auto-parts.htm...category_id=59
Hyperco HPS "Z06+10%=579" rate http://www.vansteel.com/index.cfm?fu...p=1949&ID=2873
Hyperco HPT "T1+10%=641" rate http://www.vansteel.com/index.cfm?fu...p=1949&ID=2874
or GM T1 "582" rate at a significantly higher cost, in theory that should be about the same as the HPS.
#68
Supporting Vendor
I'm a Hyperco distributor and the pricing is nice... like less than $500 a spring. But I also don't think you need that much spring rate (or want it on street tires).
#69
I have a VB&P front leaf that measures "1115lbs/in" according to what is written on the leaf itself. I find its street manners to be quite nice in combination with the Z51 rear leaf. In my observation the rear leaf will make the biggest difference in ride quality on the street. I think this is because where you sit is very close to the rear axle and quite far away from the front.
#71
Supporting Vendor
Not unless you wanna ream 1st gear all the time. But I think it's mostly a non-issue. The way headers and a tune woke up my 2001 Camaro I think the power will be more than adequate to exceed the grip of the tires most of the time. MHO
#72
Lane, what are you actually targeting for ride frequency? I haven't gone back through all my math, but plugging numbers into my setup sheet says the HPT (625/850?) combo is ~2.06/2.25Hz. Seems a little on the soft side, but is a pretty reasonable spread. Enough front bar ought to make that work?
A 2.2/2.4Hz setup would require 715f/975r springs measured the not-VB&P way, nobody does anything like this so I imagine there is good reason?
The HPT Front, Z06 rear setup comes out to 2.06/2.06Hz using my corner weights. I'm sure that'll work fine handling-wise, you'll just have a little more oscillation on bumpy lots.
#73
Wheel offset question.
What offset will we need to fit 18x11" wheels? Will we need different front offset than the rear? Can we get the wheels and tires completely inside the fenders?
#74
Probably because the autocross crowd is so small and everyone else usually switches to coilovers is why you don't see more options for stiffer leaves on-the-shelf. Its been mentioned here that stiffer leaves can be custom-made by Hyperco, and I know that VB&P can do the same. If memory serves, VB&P can go up to around 1400lbs using their method of measurement. It would be nice to round up a bunch of different springs and get them all measured with the same machine to get a feel for what's what.
#75
Jumping in to follow along. After 10 years in F125/KM I need something less abusive on the body. Carry on...
#76
You want a ~65mm offset in the rear and it will pretty much sit inside the fenders. I'm not sure about the front. My 73mm offset 11" wheels appear to fit up front but I did not test how far the wheels can be turned before anything rubs.
#77
Anyone want a set of Forgestar F14 Gunmetal 18x11" 40mm offset? I have a feeling these are a better fit for a C6 Z06/Grand Sport. I bought them from a C5 owner, and figured they would be right for my car, boy was I wrong. Fronts stick out, over an inch, rear stick out, but are close, I would say half an inch out.
#78
What brand/style rims are you using? When can you find out if they rub up front?
#79
I'm hoping I can keep this type of setup (which is what I have now, at least in terms of pipe orientation), however headers and race cats are going to make it LOUD so I think we'll all need something once we go the power route.
#80
Hypercoil is the standard in spring design and quality. If I'm buying parts, I want to buy the best. Nothing against VB&P, I know a lot of people that are happy with their products and they have been helpful with some of my questions. As an added bonus, Sam sells the Hypercoils and I plan on buying as many of my parts through him as possible since that's how you get his setup help.
