Circle track Groupon
NC Events Coordinator
I signed up for some laps at a local circle track. I'm thinking of getting a late model stock car as a track day car and this looks like a fun way to find out if I'll like driving these cars.
I genuinely believe there is nothing more intense than short tracks and bull rings. A shop, hauler and setup knowledge are all must have. A LM class that uses a durable tire and a cheep crate like the 604 will help out a lot financially. 800$ a week for tires and 40,000$ engines get old in a hurry. New cars are very expensive to build and sort out. Cheep race cars are even more trouble and expense. A front running car with setup sheets is the way to go for a lot of reasons. Good help is a must. The greener the driver is the more seasoned the spotter must be. The spotter is the most under rated hand at the track. If he is a good set up man great. These guys are hard to find and very valuable. Then you also need somebody to take tire temps. This can be a helper / tire specialist or a set up man. It can not be the spotter. A decent team running mid pack or up front is a lot of fun. Every inch of a short track is off the chart busy busy busy. Intensity cubbed. For me nothing is more gratifying than pushing your way to the front like a fat chick in a buffet line. Making laps is fun but if you run one feature in a completive short track late model you will be hooked for life. There is nothing like it.
I switched from road racing to dirt late models last year. It's taken me some time to get used to everything, but I've learned alot over the past few months and continue every time I get on the track. Lots of cars to race with no matter where you go, which is awesome!
I'm glad I started in road racing and I've been able to apply alot of driving technique I learned from that over to dirt racing... it requires a much different approach, but it's still tons of fun.
It's a tight fit, but yeah through the window. I have a full containment seat too so I've had to really practice getting in and out of it quickly in case of a fire with my helmet on. I don't see how some of the bigger guys do it.
