Need Advice - C6 Coupe for HPDE car?
Greetings all,
I have decided to no longer used my 2008 C6 Z06 for HPDE's and will now use it only on the street. I am considering the purchase of a 2008 or newer C6 base coupe as a replacement. I thought about the C5's but my familiarity and preference is with the C6.
Here is my reasoning (please feel free to critique):
1) base C6 has steel frame which is much easier to cage than the C6Z aluminum one
2) LS3 much cheaper to replace than LS7
3) $30k of less for a 2008 or newer C6 base Coupe with less than 50k miles
Input on these questions would be much appreciated:
1) would a Grand Sport be a better choice for about $5k more
2) do Z06 wheels OEM fit the GrandSport
3) what are 3 best track tires (slicks) for the C6 base coupe
4) I used Hoosier R6's on my Z, do they make sizes that fit the C6 Base coupe
5) what insurance do I need, theft, liability, etc, besides track day insurance
Thanks in advance
Thanks in advance
Greetings all,
Thanks in advance
Thanks in advance
There's one reason to consider the base over the GS as a track car - economics. If you've got the extra cash to operate it and buy it it's no big deal, but the GS has higher operating costs. Tires and brakes are both significantly more expensive for the widebody than the standard body cars. If the operating costs aren't a concern, go widebody.
I'm going to play Devils advocate on this situation. Are you going to sell the Z06 ? If not the additional car is a huge expense. You will have to spend substantial $ to bring the coupe up to anywhere near the performance level you got from the Z. Seems better deal to me to just make the safety and other mods you want to the Z and run it. The Z is a much better base car to start with for track use.
Seems like the wrong direction, the Z with the dry sump, better brakes and extra cooling is a better track car? Plus you know what you are starting with and not someone else's problems.
The base coupe is a more comfortable street/touring car, especially with F55 suspension, and gets 30mpg on the highway.
The Z is amazing on the track but I can live with well sorted, safer coupe.
My opinion is get a track spec c5 coupe or z06. The motors are more reliable without a dry sump. The abs is less intrusive. They're also a lot cheaper. It seems late model c5 coupes already setup for hpde cost around 15k. It also won't sting nearly as bad if you plant it into a wall.
Buy a car already finished but if not C5Z06 > Base LS2 C6 (boom).
Good luck!
I did this same math and ended up with a 2010 GS. But in all honesty its really only worth it if you need a dual purpose car.
If you want a dedicated track car, I would actually look for a prepped T1 or ST2 car. They'll already have all the work done, and you won't have to deal with the teething issues that the GS / base cars have (calipers, brake ducts, dampers or coilovers, and sway bars).
Plus, full cage and hopefully a cool suit setup
The GS takes really well to the same tires as the Z06. I run R888s because I drive to the track, but they'll take the same hoosier setup as a Z06 without issues.
Or buy one of these (ex ASA racer) for 17-25K and go faster for less operating cost and be safer.
LS1 powered, 400 HP plus to the wheels on pump gas, 2800# with driver
This is Trans Am 2 Champion Cameron Lawrence's ex ride (2012 V8 StockCar champ car)
lap times: Daytona 1:57 Sebring 2:14 Road Atlanta 1:29
+1 on this...not that I'm biased (LOL..I am!)!
I agree, if you don't want to drive the car on the street then there is no point in starting with a street car. I'd personally go for something much smaller and lighter, but those ASA cars are pretty sweet for the price.
If you must use a street car, buy one that's already been converted to race in SCCA/NASA for the same price as a regular C6 street car.
