Track day wheels 17" or 18"
Old 10-06-2014, 02:49 PM
jranaudo
jranaudo's Avatar
Default Track day wheels 17" or 18"
What do you guys suggest for an extra set of track day wheels? Looking to go square all around but not sure on size. I have heard some people tell me to go 17" because there are more tire options at this size. Any recommendations?
Thanks!
Old 10-06-2014, 03:01 PM
Scooter70
Scooter70's Avatar
There are many more options for performance tires (and race scrub slicks) in 18".
Old 10-06-2014, 03:11 PM
63Corvette
63Corvette's Avatar
Most here run 4 stock rear 18" Z06 wheels, and many also run a "square" tire package to limit "push"or make it more neutral.
Old 10-06-2014, 03:36 PM
troyguitar
troyguitar's Avatar
17" track tires are cheaper if you buy new, 18" are more available if you buy used. 18" also is compatible with bigger brakes if you choose to upgrade those down the road.
Old 10-06-2014, 06:32 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Way more options when it comes to tires in a 18" and it also will allow far more brake options given you have the right spoke to caliper clearance.
We are now seeing 19" race slicks so it will only be a matter of time before you have a good selection in those as well.
Now given you are running approx the same tire height...a 18" will have a shorter and stiffer side wall with it as well.
Old 10-06-2014, 07:34 PM
yakisoba
yakisoba's Avatar
i used to run 17. Can't get good scrubs for them. Run 18 now.
Old 10-06-2014, 11:00 PM
jranaudo
jranaudo's Avatar
Thanks for all the responses. I was told lots of scrubs available in 17 but I see its the opposite now. Off to find me a set of 18" wheels!!!
Old 10-07-2014, 09:59 AM
LateBreak
LateBreak's Avatar
I run on 17's but we're on stock brakes and can't run slicks(cheap scrubs) so I do it for the cheaper new tire selection...
To Track day wheels 17" or 18"
Quick Reply: Track day wheels 17" or 18"
