SPA Fire Suppression System Feedback
Hey guys,
I am in the process of looking for a fire suppression system for my C5 and am leaning towards the SPA 4 liter unit.
For those of you who have experience with it, please let me know what you think. Would you buy it again/recommend it?
Are there any other units that you would recommend instead?
Thank you
Thank you
Here's an article I wrote a year ago. You have some real choices to make when it comes to fire systems.
Richard Newton
Richard Newton
I'm not that thrilled with Spa Design products, had problems with their early sequential shift lights.
This year we had the connector on the fire system power pack break on one of our Formula Atlantics (but I'm not exactly sure why it broke).
So, I'd rate them as just OK but not great.
I installed 3 systems this year, all were from FireBottle.
Their customer service is great.
The only thing on their system is that the driver's hose/nozzle is under pressure from the factory and can't be removed from the bottle for installation but that hasn't caused me a problem.
I also need a fire system and was leaning toward firebottle but find the Coldfire system very appealing. If anyone has fire system experience and could provide some insight into why or why not one should consider the coldfire system I would be greatful.
http://www.coldfire.biz/racing.htm
But I don't see an on board system on their website.
Deist has a fire system that uses Cold Fire. I think I saw more options using cold fire that had an automatic function depending on the temperature. I'll post url if I can find it again.
http://www.deist.com/fire-systems-c-38.html
I've got an SPA system and I'm very happy at the moment. I just got an price of $352 to refill the canister (OG Racing). To refill, you have to replace the dip tube assembly as well as the electric valve.
There has to be a better system.
Jim
Jim
Jim, I get the Firebottles refilled for $160.
Did you have to discharge the system? If so, how did it work?
Racer parts wholesale shows $99 for non-discharged bottle service/refill or $199 for discharged bottles (electric 4L systems).
http://www.racerpartswholesale.com/c...ottle_Refills2
Mechanical systems are only $86 for refills.
I have an ESS (Emergency Suppression Systems), dual pull, mechanical system. It is supposed to be user refillable although I have never done it. The instructions look pretty straightforward. I've never had to use it so I can't really comment on how well it works. The system isn't the prettiest.
Being in Texas, you might not care, but one thing that is a little annoying about the ESS fire system is that since the tank contains a significant amount of water and my car is in an unheated garage in Michigan, I have to remove the tank each winter. This is per their recommendation. I'm not sure if all the foam type systems or other systems require this.
NASCAR requires 2 bottles. One is for the fuel cell.
The other thing to consider is where (and how many) nozzles you're going to use. That's more important than the brand of the system
This is a very early Porsche that's being used in vintage racing.
Richard Newton
Historic Racing Images
Richard Newton
Other than the refill cost, how do you like the system?
The discharge was inadvertent during some other mechanical work.
Thanks for the info; I'll look into those alternatives.
Jim
