couner weight
corner weight
I did a search and nothing cam back. So the question is since C5s have wider rear tires would you still want to have front to rear weight 50% - 50%. and changing tire size change optimum weight %. What side of the fuel tank drains first?
OTOH, if you upsize the fronts to a "square" setup you can add more front roll stiffness and that can work too. Lot of folks here are running square setups and after they dial the car in it works just fine.
It's all in how you want to set up the car. Remember, that looks enter into it to, and bigger rear tires are important to the stance of the car.
Bottom line is that you can make a pretty wide range of setups work, you just have to work through it and get the car balanced in terms of shocks, spring rates and roll stiffness.
In a perfect world you would size the tires for the weight distribution, and then tune the car, but there are bunches of reasons why this isn't done.
For an example, GM didn't want fatter tires on the front of the C5 because it hurt the aerodynamics and increased fuel consumption (CAFE numbers are important to every car in a manufacturers line). When they came out with the Z06 they upsized the width because the car needed more front tire, although it hurt the mileage.
To get a car to handle properly you need "enough" tire, but after that, more tire doesn't help much in increasing grip and improving handling. There is definitely a case of diminishing returns with increasing tire width.
With suspension tuning you can take cars that don't have optimum weight distributions and tire combinations, and make them go pretty darn fast, it's all a matter of getting the car balanced, and there's a range of tuning that can get the car there even if the package isn't perfect.
Here's an article I did on corner weighting. You want to pay attention to the cross weights. They should be within a lb. or so. With the car with you in the seat. I like a half tank of gas.
http://2.bp.blogspot.com/-RDpLQX_ZNz.../Scales+2w.jpg
None of this is going to be easy you'll spend hours on this. Then hours on the alignment. Then back to the weights. Don't forget to disconnect your sway bars
Richard Newton
Richard Newton
