Safe location to drill and tap for diff temp sensor
I'd like to add a diff temp sensor to my 07 Z06. Anybody know a safe spot to add an 1/8 NPT port to differential case? Some place near the drain would be ideal...
Thanks!
Thanks!
Answer: right by the 'A' in "GETRAG"
I pulled the drain adapter (pump inlet) out and felt around inside. I could see and feel the ring gear so I kept the hole in line with it. I tested the arrangement by sticking a drill bit an inch further in and rotated the wheels to test for interference.
Drilled and tapped for 1/8 NPT, then use the Stack 1/8 NPT to 6mm adapter. Sensor is a Stack ST991
Platinum Supporting Vendor
You can put and adapter and tee off it. You can also go out near the Drivers side cover, it is away from the ring gear. You would be better off not to though. The diff does not really get that hot, just make sure you have the oil filled and you will be good. Since you have a Z you can also take out the line on the bottom that feed the pump, install and AN line and use and adapter to use a factory ECT sender. You can get the AN fitting that fit the pump and the lower elbow. This way you just use a 6 an line with fittings. this way it keeps you from having leaks that could be associated with drilling and tapping the housing.
That was my original plan (to tee off the cooler plumbing), and I even converted the lower fitting to AN6 ORB, but the plumbing to adapt to the Stack sensor (can't easily use a GM sensor with the Stack data recorder) was god-awful, with two pipe threads in the setup. All those fittings have more chances of a leak compared to the single pipe thread in the case, in my estimation.
The Stack sensor extends 1.5" (40 mm) and uses a 6 mm thread. So the direct to the case method is better: the sensor is measuring the fluid temp in the sump of the diff case as intended.
As far as the diff not getting hot, that's not my understanding. I've been told that one of the reasons for the transmissions overheating on track days was due to the load of also cooling the diff. With high fidelity sensors and data recording, I'll know for sure, one way or another.
There are also some threads regarding hot differentials, some to the point of melting plastic fittings. I'm still trying to figure out a way to adapt a differential cooler in a way that doesn't necessitate cutting car components like fender wells, brake ducts, etc.
