Turn all traction control off?
I have a 2008 A6 base corvette that I put rear C5 rims with 285/35/18 on all four corners. I have read before that the traction control system will not work since I change the tire sizes. Does that mean that competitive driving mode will not work either? Do I need to hold the button down for 10 seconds until it turns everything off?
Thanks guys
Adam
Thanks guys
Adam
Thanks guys
Adam
Thanks guys
Adam
Gasoline Addict
Thanks guys
Adam
Thanks guys
Adam
This is great to hear. I've been looking at an 18" square setup and had gotten stuck trying to find some tires that had the stock height difference front to rear.
Received 8,929 Likes
Some cars will have TC issues with a square setup some won't. I ran a square setup on my 97 and C5Z and never had an issue with TC on either car even they used different EBCM designs. I did know some people who did have issues with their C5Zs where TC would activate when the speed approached 100 mph. I think the difference comes in the tolerances found in each EBCM. However, a square setup will not cause AH to activate. If you have an issue with TC all you have to do is turn off TC with the button.
Bill
Bill
Gasoline Addict
Bill
Bill
I find it best to run AH off completely on the track. Used to have brakes go quickly into ABS when braking after AH was active on a tight section of turns.
If new wheels have Tire pressure sensors on them you should b ok
I just pulled the fuse on my C6 Z06 TC, I'm faster without it & TC really goes crazy on NASCAR banking
