Strong Diff Fluid Odor
Old 11-25-2014, 01:00 PM
BierGut
BierGut's Avatar
Default Strong Diff Fluid Odor
I had little reply in tech forum so I am re-posting here... apologies about the cross post...
Symptom/Issue:
'05 6 speed that had it's diff fluid changed one year ago to AMSOIL fully synthetic. Diff is not overfilled and does not leak. Drove the car for 6 or 7 months with ZERO odor. Following my first track event in the summer there developed a very strong diff oil odor that would drift into the car every 5 minutes or so on drive. Replaced the diff breather and it's improved the issue about 60-70 percent, but diff fluid smell is still there every few minutes. Inspection of the diff breather revealed the old one's rubber or plastic washer was essentially gone/melted, etc... So the decrease in smell makes some sense. But I still get an unpleasant odor and would like to alleviate it.
Questions:
Is this just as simple as the brand of diff fluid I used?
Is the smell an indication it's burnt and needs replacing?
Would Mobil 1 or GM's fluid not smell? (or smell as bad)
TIA for any thoughts or solutions if anyone has had same issues.
-- BierGut
Old 11-25-2014, 01:08 PM
ErnieN85
ErnieN85's Avatar
Symptom/Issue:
-- BierGut
Questions:
no they all smell the same it's the additive
No new smells just as bad
nope
now for where it is coming from.
it doesn't take much so the best indication is a dusty spot as the oil will attract dirt to it. There are many spots that a leak can happen
usually it is the oring on the side covers, next the axel seals. then fill and drain plugs, Vent & the input shaft seal between the trans and the Diff.. as I said clean it up with brake clean then watch to see where it gets dirty
the joints on the axel are black so it is really hard to see there wipe your finger over them and check it that way
good luck
Old 11-25-2014, 01:25 PM
BierGut
BierGut's Avatar
Originally Posted by ErnieN85
Questions:
good luck
It's been checked twice by technicians; private and dealer, but to what extent I am not 100% certain. I was told there are no leaks, but perhaps they just cleaned off the area above the breather. I would have to question them.
What I found interesting is the DECREASE in odor once breather was changed but not the elimination of odor. It correlated with the original breather lacking the rubber gasket the new one has.
Old 11-25-2014, 02:57 PM
ErnieN85
ErnieN85's Avatar
it also might be thhat there is some oil they didn't clean up
as in if you want it done right...................
Old 11-25-2014, 03:05 PM
BierGut
BierGut's Avatar
So true...
Old 11-25-2014, 11:03 PM
froggy47
froggy47's Avatar
Everything Ernie said.
Old 11-26-2014, 07:22 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
As mentioned above, the smell is the extreme pressure additives and they are in all diff fluids. My wife HATES that smell.
There are several leak paths out of the diff. Don't know if they are as common on the C6 as the C5, and assuming your 05 doesn't have a diff cooler, the diff gets very hot at the track - to the point of melting portions of the diff in very long sessions at hot track days.
Left axle seal - common failure point on the C5 diff and won't get better with time.
Vent - It will release some fluid mist as the diff heats up. It can melt if the diff gets very hot.
Speedometer sensor - on the top passenger side of the diff is the sensor for the speedometer. When I lost my left axle seal in a race back in 04 and lost about half my diff fluid, my diff got so hot this sensor melted. Speedometer went away with about 5 laps left in the race. I finished the race, then rebuilt the diff. If your vent melted, I suspect you've partially melted this sensor as well and this is likely your vent path. It is all but impossible to see unless you drop the diff.
If you can smell diff fluid, you are losing it. At a minimum, I'd top it off prior to each track day.
After about 10 years of racing, last year I finally added a DRM diff cooler to my C5. I think the diff runs much hotter than I had formally thought.
Good luck finding and correcting your leakage source.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 11-26-2014, 07:47 AM
el es tu
el es tu's Avatar
Could it be that someone got diff fluid on themselves while servicing the car and now some interior part still has the fluid on it?
Nothing ever really gets that smell out of fabric...
good luck on the search!
Old 11-26-2014, 08:48 AM
BierGut
BierGut's Avatar
Excellent post - Thanks. I know it misted all up under the car and as you mentioned, as the techs told me this is what they found. Examination of the original breather shows it melted inside so we know it got pretty warm. Thanks for the heads up about the speedo sensor -- but it doesn't sound like we'll be looking at it anytime soon. (Ha)
The level is currently fine. I wonder if the diff was originally over filled and this was, at least, responsible for some of the misting. I'll have it thoroughly cleaned up under there and we'll see if we continue to get odor.
The one comment that you made that is always in my head is "if you smell diff fluid, it's leaking somewhere." Somehow I just get the feeling it'll show itself after a couple of track events next season.
Thanks again.
Old 11-27-2014, 09:37 AM
C66 Racing
C66 Racing's Avatar
I suspect your speedo sensor has partially melted (given you melted your vent) and then hardened when the diff cooled. It really isn't more than a plastic insert with an o-ring held into place with an external bolt on a tab. I believe it has a magnet in it that senses the gear teeth as they rotate by it. The magnet is probably still in place since your speedo works, but my guess is that either the o-ring or plastic insert has melted and there is an air gap. I don't remember the size of the bolt, maybe 10mm. You might be able to get your hand up on top of the diff and get it off to inspect it.
I do not believe left over diff fluid is your problem as that will dissipate rather quickly when you get everything hot. If you notice the smell more on long sessions than short, almost certainly you have a leak that gets worse as the diff heats up.
Old 04-29-2015, 03:47 PM
BierGut
BierGut's Avatar
Car is in the shop now so I am waiting on news...
If it's the speedo sensor that has melted, what remedy does one have for an upgrade to this doesn't just continue to happen?
Old 04-29-2015, 03:59 PM
ErnieN85
ErnieN85's Avatar
wrap the sensor in some heat tape summit racing has it
Old 04-29-2015, 04:02 PM
BierGut
BierGut's Avatar
Thanks, Ernie.
To Strong Diff Fluid Odor
Quick Reply: Strong Diff Fluid Odor
