25 Days of Christmas (daily deals) plus $$$ for K9s for Warriors
Former Vendor
Well folks the 2nd annual 25 days of Christmas starts now
Everyday we will have a new sale item up on the forum. Not only will you be receiving a good product at a good price, but we will be donating to a good cause. Last year we donated to the Wounded Warrior Foundation. This year it will be to the K9s For Warriors. http://www.k9sforwarriors.org/
I love dogs and my respect for the Veterans goes without saying much.
Well enough of me typing away lets get started.
Thank you
Randy Rippie
336-350-8256
Thank you
Randy Rippie
336-350-8256
Former Vendor
Day 1 (Ends 12-2 at 5pm central)
DRM C5 Brake ducts
Instead of blowing air aimlessly around the wheel well, these brake ducts finish where GM left off. Air is blown directly into the hub/rotor area to dramatically reduce rotor temperature. Works with up to 10″ wide 18″ tall front rims. These are now standard equipment on our C500/RSR.
We recommend using these in combination with our Stainless Steel Braided Brake Lines and Stainless Steel Pistons for the ultimate in repetitive and high speed stopping performance with stock GM calipers
Kit includes left and right ducts with high temp hose and clamp. All hardware included with instructions. 2 hour installation time.
A must have for any modified braking system.
$170.00 and we will kick in 20 for the K9s For Warriors
http://dougrippie.com/products/c5-brake-ducting/
DRM C5 Brake ducts
Former Vendor
Day 2 (Sale ends 12-3-14 5PM)
The factory aluminum pistons are a huge heat sink, rapidly transmitting heat from the pads into the fluid. DRM’s stainless steel pistons insulate the fluid resulting in a more consistent brake pedal and less chance of fluid boil. When high performance or racing pads are used these pistons are considered a must.
These Stainless Steel Pistons will fit C5 base, Z51, Z06 and also C6 base, Z51
Save 20 bucks ($119.95) DRM will add 15 to the fund
http://dougrippie.com/products/drm-s...steel-pistons/
Former Vendor
On the 4th day (sale ends 12-6 at noon)
This all in one package has been a very popular upgrade. The Ron Davis radiator really keeps both the water and oil temps in check during HPDE, Road Racing, and other applications. The radiator drops into the same location as your factory radiator. DRM Pre-built Line kit is formulated for a easy install, right line length, and race proven parts. The Block adapter sits above the stock oil filter, so your stock filter fits in the stock location
Save 100 bucks and we will put 50 bucks into the K9 fund
http://dougrippie.com/products/ron-d...-and-line-kit/
Former Vendor
On the 5th day we gave the C4 guys something to pick up (sale ends 12-8 at noon)
Trailing arm brackets Precise weight transfer is critical for optimum acceleration, braking and cornering. DRM brackets alter the trailing arm mounting point locations to promote better geometry. The additional weight transfer results in improved traction. Improvement will be realized at autocross, road course and drag racing events.
$95 dollars shipped and we will throw in 15 to the K9 Fund
http://dougrippie.com/featured/c4-tr...kets-in-stock/
Former Vendor
On the 8th day
Tranny cooler.
As the temps climb under extreme conditions, let DRM’s Transmission Cooler Kit keep those temps in check.
DRM coolers have been tested around the world at many different race tracks. They have been tested to 600 horsepower in roadracing applications. It will bring your fuild temps down to a cool level. They mount in the factory ZO6 duct location. There is a small amount of wiring needed. The kit includes the pump, cooler, aeroquip lines
600 bucks shipped and DRM will throw 30 bucks into the pot.
http://dougrippie.com/products/drm-c...on-cooler-kit/
Tranny cooler.
This is fantastic, I love the work that K9's for Warriors does. I found out about them because of a dog rescue organization I donate to.
In case you or anybody else doesn't know you can donate to K9's through amazon; set it up and place your orders through smile.amazon.com and Amazon gives a portion of your purchases to them or your other charity of choice.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
V. nice thing to do! ttt
Former Vendor
I owe many apologies for this years sale. First couple of days everything was good. Then we got in our 2400 pounds worth of Bilstein shocks, then my Mother in Law came into town. Then I got sick, then I had a Gout flare up and had a hard time getting around. Lets just say this my past couple of weeks have been hard on me. So I let the sale slip away. But doing 100 percent better now and with the new year coming, the future is looking good!!!
I will be writing the check today to the K9 For Warriors
Randy
Randy
