Trailer suggestions...
Received 8,928 Likes
First thing is tool boxes don't have to go on the bed. They can go in front of the bed on the tongue and a fair number of people put them there even on longer trailers. Tire Racks can be built over the car and the trailer bed.
My tire rack starts at the beginning of the bed and is about 3.5 ft above the bed. With 4 tires in the rack and the car placed so the trailer is balanced properly there is enough room to store a folded pop up tent in front of the car. If I wanted I could weld a tool box on the tongue in front of the tire rack. However, I would have to move the car rearward 3 or 4 inches to compensate for the added tongue weight.
Bill
Folks, while I appreciate the concern, I'm not asking for tow vehicle suggestions. I've towed nearly 10,000 miles in the Touareg and it's been a sublime tow vehicle; much better than the pickups I have borrowed to tow in the past. I have a Tekonsha Prodigy 3 brake controller and the factory Class IV receiver. The brakes are massive, it's 4WD, and it's a porker. Long trailers are a concern due to its 112" wheelbase, but I'm comfortable towing anything up to 20' and 6000+ lbs (it's rated to 7716 lbs). Many on the Touareg forums are towing enclosed trailers, Airstreams, and the like. I realize we're on a Chevy forum but let's keep an open mind. (Heck, there's another Touareg and a Grand Cherokee already cited as tow vehicles in this thread!)
To those of you who have made specific trailer recommendations based on my criteria, thank you! I'll look into the Neo and Quickload trailers. Featherlite is already on my radar so thanks for the affirmation!
Supporting Vendor
If you can swing it a quality aluminum one is the way. I've had a lot of trailers. Steel, open deck, closed deck, and two aluminum ones. A Featherlite 3110 17.5' and now an Aluma 8218Tilt. I still have a steel trailer, I use it to tow my A-sedan car to the track.
I also have a lot of truck, as in a Cummins powered Ram. 800 ft/lbs of torque, and the truck is 8000 pounds. Pulling the steel trailer vs. either of the Aluminums is a massive difference. MASSIVE. This is even more the case with a smaller truck. And remember that the heavier the trailer the more easily it can shove your truck around.
Resale is better too, but they aren't cheap. And a lot of trailers will need supplemental ramps for the low nose on the C6 GS's and Z's in particular. The Corvette won't even work on the steel trailer unless I want to crawl out the window (I don't) because the door won't clear the fender.... so no matter what a removable fender is a smart idea.
FWIW, I am a Race Ramps dealer, and I use them. Not really cheap, but light and tough and likely needed to some degree with a deep nose C6, less so with C5's especially ones that aren't lowered.
__________________
Sam Strano
Strano Performance Parts
www.stranoparts.com
814-849-3450
More options than any other single company out there. More parts than any other single company I know: Brakes to Safety, Wheels to Exhaust. Suspension to Air Filters: Girodisc, Hawk, Raybestos, Essex Racing/AP, Ferodo, Wilwood, Penske, Koni, Borg Motorsport, Ridetech, Viking, After Dark Speed, Hotchkis, Bilstein, KW, Forgestar, BC Forged, Forgeline, MRR Wheels and on, and on, and on it goes.
Sam Strano
www.stranoparts.com
814-849-3450
Gasoline Addict
With that kind of budget, you can get any open trailer out there, even some of the top notch aluminum premium trailers. Used Featherlites and such show up on racing junk, equipped with wheel/tire racks and tool boxes for around $5-6k. I also saw some premium, light and dovetailed trailers on other forums that are frequented by Porsche guys (they always have nice trailers - and most pull them with a Cayenne, which is just like your VW).
http://www.racingjunk.com/Used-Trail...r-Trailer.html
Here is my favorite setup, although this ad is from last year, so it's gone. But gives you an idea of what is out there. Check out Rennlist too...
http://www.6speedonline.com/forums/a...er-3110-a.html
I bought a cheap 18x7 aluminum open, dual axle, dual brakes trailer new for $3150 in MI earlier this year, that I found on eBay, and it only weighs 1360lbs. I have to use race ramps to load my C5Z on it, and my Armada easily pulls it (under 5,000lbs loaded) and I have no issues with it swaying, even in windy conditions. Gas mileage is decent too, as the setup is relatively aerodynamic, as compared to an enclosed trailer.
I really liked my trailex 8045 open trailer. Used it for 2 years and am in the process of trading it in for a trailex enclosed.
The open trailer is about 1,000 lbs, and with the 11 ft Ramps I never had a problem with my c5 or GS. People seem to love them or hate them. If you are in the NJ area mine should be at a dealer and for sale in a few weeks when I pick up the enclosed.
