C4 HPDE Tires
Yes, yes you do. I might be interested in a set depending on what you have.
What year is your c4? If you have a early model that can run the stock 16" wheels then you can get hankook c51 for $109 from tire rack. I have been running the c71 on autox and its a cheap tire to learn the car on. They are very sticky for being only a 255 will be even better when i get the camber dialed in.
