Plastic windows - what thickness?
Considering there have to be some folks here that have used these I figured this was the best palce to ask (car is a c6 if that matters):
Im looking at the optic armor catalog and they have quite a few choices for the window thickness. What thickness for each application would I be able to get away with without having to use reinforcements?
They offer 1/8" 3/16" and 1/4" for the windshield rear window and side windows.
Thanks!
Thanks!
Depends on the group you run with. I know in scca, the window thickness is set by the GCR... Plexiglass reinforcement is noted in the same location of the GCR as well.
The scca solo rules just state a minimum 1/8" and reinforcements are optional.
Im just not sure I can get away with rear hatch glass that thin without a reinforcement like katech did for their setup...
Just found a thread where Jason from Katech mentions their side windows are 3/16" thick
Taking that into account, the 1/4" option is probably going to be the best bet for a windshield or rear hatch
Premium Supporting Vendor
Thanks!
Thanks!
1/4" is good for the rear.
