RedLine RL-600 DOT4 Full Synthetic Brake Fluid
Former Vendor
St. Jude Donor '13
High-Performance Synthetic For Street/Track Use
Engineered to maintain viscosity and lubricity at extreme temperatures
Safeguards against vapor lock and brake fading
Blends with and meets specifications of DOT 3, DOT 4, DOT 5.1
600 degrees Fahrenheit dry, 400 degrees Fahrenheit wet
Available as six pack for easy inventory management.
– Red Line now offers its own high performance brake fluid perfect for street or track use. RL-600 High-Performance Brake Fluid is engineered to maintain viscosity, lubricity and compressibility at extreme temperatures to help safeguard against brake fading and vapor lock in racing, performance and street applications.
RL-600 blends with and meets specifications of DOT 3, DOT 4 and DOT 5.1.
Note: Red Line RL-600 is not silicone based and compatible with most factory brake systems and fluids. Always follow vehicle manufacturer's recommendations when adding brake fluid!
http://www.xplosiveperformance.com/R...00_p_3690.html
Retail Price: $19.95
Your Savings: $3.00
Your Price: $16.95
Former Vendor
St. Jude Donor '13
Your Savings: $3.00
Your Price: $16.95
I'm currently running Motul RBF600 in one car, and Castrol SRF in the other, So, what can I "mix" this brake fluid with......or, do I have to completely drain and flush before changeover. Is it compatible?
Former Vendor
St. Jude Donor '13
The Redline RL600 is compatible with most DOT 4 fluids Castrol doesn't recommend adding any other fluid to theirs. Your currently running 2 excellent fluids and if your not having an issue don't change. We also sell a lot of Motul (our first choice and in all our cars) and the Redline is an excellent fluid at a little cheaper price point than the two other fluids for people who maybe replacing a standard Dot 3 who are doing a few HPDE events a year.
Former Vendor
St. Jude Donor '13
Your Savings: $3.00
Your Price: $16.95
Former Vendor
St. Jude Donor '13
Your Savings: $3.00
Your Price: $16.95
Former Vendor
St. Jude Donor '13
Your Savings: $3.00
Your Price: $16.95
