Max tire hight for C6?
Hi members,
I'm in the process of getting the wide body installed and the Wheels to go with it need shoes :P
Wheels spec is 19/10.5 Front and 20/13 rear.
The suggested tire size are 285/30/19 Front and 345/25/20 Rear
Now the Choice for super sticky tires in these dimension is really limited I can get Nitto invos (which I was told not to get) Toyo T1r (highy raccomended but still a Grandtouring compound) Pirelli Zero's ( absurdly expensive and despicable grip levels) Pilot Sport CUPs (with 335 rear but wear really fast)
Sooo I was thinking to think outside of the box and go perhaps with the new Pilot Spot cup 2.. however those come 1 size bigger.
285/35/19 and 345/30/20.. They will be 26.9 and 28.1 tall respectively so in terms of ABS are ok BUUTTTT.. will they rub anywhere in the wheel arch?
Any one has tried those and worked fine?
Thank you for the inputs
Is it possible or it will rub ? dontwant to fork out the cash to then find out it does not fit :/
any inputs?
