Big Meats, please (C5z)
First official tech thread started on this forum, so treat the newb kindly please
I've done the reading and still don't have a definitive answer. I have a c5z that I'm prepping for the track. Intended use is HPDE days mostly with some AutoX, but not much (80/20). I've read Zenak's sticky and am pretty sure bushings, motor / trans mounts and coolers will be first on the list. Seats, harness and harness or rollbar will be next. At some point BBK and suspension mods. I figure I'm in for months of cash burn and wrenching.
Onto my question: What size and how big of tires can you fit in the front and rear of a c5z without flaring?
I know Popp runs a 315 / 335 but not sure I need to go quite that big?
I'm 'thinking' 18x10.5 285 or 295 tire front and 18 or 19 x 11.5 rear 315 or 325. I"ll mock up a sway bar and brake ducts for clearance and see how far I can go. I'm pretty sure I know the BS measurement to get close to zero scrub, and a balanced track set up is the goal. I know tuning will be involved no matter what I do, and would prefer to not have too much under or oversteer right out of the gate due to a bad decision on tire sizes.
Whaddaya think?
Whaddaya think?
Whaddaya think?
Whaddaya think?
(no flames please, this comes from a successful race team owner and suspension guru).
I know this because his 17x11.5's and 17x12.5's are on my car still , bought them out at Wendover ProSolo eons ago. IIRC, he sold them to me as he was moving to 18's and a 12" () front, based on his testing showing greater grip. The wheel rub must have been substantial around paddock Been a long time though, I could be misremembering.
Myself, I'm inclined to do something similar, and with the wide front and rear fenders (L5 etc) available these days, try to run a 335 square and see how that does ...
As the earlier posters have said, it would seem that a great way to get to a 90% setup is to get 4 Z06 rears with 315-18's, and go have fun.
Cheers!
-Jake
Also Steve what tires are you running? Most 315s want an 11" rim.
I've had smallish 315s ( Nitto NT-01s) on 18 x 10.5" speedline rims at all 4 corners but they provide a lot of rolling resistance and rub a lot.
Likely would be happier with a 295
315/30/18 Hoosier A6's. Max out on neg. camber and castor.
Supporting Vendor
One of my favorite setups was running rear OEM C5 Z06 18x10.5's at all four corners with 305 Hoosiers. My car was dropped on stock bolts a bit, running T1 front and rear sway bars with 2004 OEM shocks. The edge of the tires came right out flush with fender, but never made contact. On the inside, my tires would just barely kiss my brake ducts (DRM) if I went to full steering lock in the paddock. The mechanical grip with 305's all around was tremendous, and the car was nicely balanced. I never saw the need to go bigger.
As for other mods, I think you're heading down the right track. I ran a Ron Davis radiator/oil cooler. My tranny only ever overheated if I was running in the desert during summer. Otherwise it was okay. That said, a tranny cooler will keep your wear and tear down. The OEM seat is pure *****, and a good seat will put you in touch with the car far better than most other mods. Safety equipment should definitely be a top priority if you like your head attached, and the way it is now. Brakes are my specialty, so when the time comes ask me about that.
Good luck and welcome.
what size wheel combo will fill in L5 rear fenders
I'm having L5 rear fenders with the 2 inch lip installed and want to know if anybody can tell me what size wheel combo will fill in extra space? Please include pics if available.
Has anyone tried the PSS 295/35ZR18s all arond on stock Z06 C5 18 inch wheels? Thoughts? Mostly I'd use as a street setup that I could rotate. Too much "pushing" for the street maybe?
To a certain extent I'm of the opinion of "go big or go small" though - in other words either run flared fenders with 335's on 18x12s all around to be as fast as possible or just run whatever is cheapest. I'm going to run whatever's cheapest myself, which means using 4x C5Z fronts at 17x9.5 and probably 255/40/17 Hankook RS3's at $600 or so per set.
