Brake Pad Backing Plates
Should these be routinely discarded to promote heat transfer or should the mfr be contacted to discuss exact purpose? Very lightweight mat'l, maybe Ti? Pops off easily.
The purpose of the backing plates is to reduce heat transfer to the caliper pistons and brake fluid. They do this in 2 ways. Firstly, the Ti has lower thermal conductivity compared to steel and secondly by providing two interfaces (between the pad and the shim and the shim and the piston) that provide additional thermal resistance.
If you are actually using EBC pads..... Forget about those shims, throw the pads away before you even take them on a track. I used EBC yellow many years ago and got about 20 laps out of a set (in addition to learning the true meaning of the term "brake fade"). They are fine for street but absolutely garbage for track use.
I have not yet picked up a set up Ti shims for mine, but what I do have is a spare set of pad base metal, when the pad material wears down I slide these in and it gives more metal that need to heat soak before it transfers that heat directly into the caliper pistons and takes up the extra pedal travel from the worn down pad material.
Perfect use of a worn down brake pad, the dust I created from my belt sander and the pad dust was actually pretty impressive getting the pad material cleaned off; I probably should have worn a dust mast...
It just appeared that the OP had no idea what he was looking at. And then appeared that he was convinced they were Ti after absorbing your brief post.
Limitations of thread chat, I can only imagine how many miscommunications go on with tweeting and the limit on characters (why I don't do it).
BTW I agree with another post, those are NOT in any way a track pad. See post #4, I have used EBC blue which is supposed to be more a "track" pad than yellow, they were "not useful" on a track.
Gasoline Addict
If you have Ti shims, you want to reuse them, as no pads that I know of come with titanium shims - discarding those, and putting new Ti ones each time, would get really expensive.
I always use shims on track pads, but not sure if they are absolutely necessary... as I have seen some people that don't use any. Squealing on the track is not an issue for me, and I don't think that steel shims offer enough heat resistance properties to make them worthwhile for that purpose.
