Tilted radiator tips
Hey all -
I've bugged a few folks already on this, but wanted to ask the community at large to add to my knowledge set before I start cutting parts . I found only bits-and-pieces searching here in the AutoX and C5 forums, so I thought I'd post this thread.
I'm making plans to do the whole front-feeder/tilted radiator/louvered hood/front splitter thing. Car is a 97 C5.
Since relocating the radiator in this manner on C5's seems to be relatively common, before I reinvented the wheel, I thought I'd see if there is an "easy button" approach first, e.g. "call this guy he makes brackets", or if everybody sort of takes their own approach.
If the former, can you tell me who?
If the latter, would any of you be willing to post or email pictures, particularly of the bottom radiator mount, so I can gather a few ideas?
Thanks for any pointers, suggestions, or images.
Cheers!
-Jake
Cheers!
-Jake
In looking at it, my plan so far is to remove the factory support, cut off the two lower mounts, and use those as a basis for fabbing up a simple new radiator mount. Will make a jiggle strip or similar to attach the upper to the front frame crossmember with a bit of weatherstripping for padding.
Doesn't look too hard, but I was hoping for the "send $100 to this guy and he sends you the parts"
-Jake
-Jake
TRAKOUT (01-29-2020)
There simply isn't enough room to make it easy. Can't move bottom rearward much,and stock radiator is too tall to lean forward. You have to lay it almost flat, which does give much better airflow than oem. I personally think a good center good and some good shrouding can work with oem radiator location
I'll play with this soon on a project car, but not convinced it's worthehile
I can take pics tomorrow.
I did this project 3 years ago, I still have a lot more pictures if you need anything specific let me know.
Maybe this will help you some
https://www.corvetteforum.com/forums...o-project.html
I put riv nuts into the frame rails to attach the radiator, on the radiator the Ron Davis has factory type slots that hold the fan assembly I used these for mounting points.
I have always wondered how much the air intake temperature was rising with this setup.
It looks like there is so much warm air blasting on the intake duct, I was wondering if that could outweigh some of the engine cooling benefits.
I'll be doing one of these for my car. And we will take extensive pics of the fab work. Eventually if plausible, JB Corvettes may produce a kit.
How does radiator size effect this new orientation? I'm having a custom 4" core unit built.
I did it more for room under the engine bay than any change in cooling. The stock rad location is @$#%$ for doing anything on the front of the motor, especially when the car is hot at the track.
Keep in mind, it doesn't need angle to function right, mine is basically flat with the splitter ducted to the bottom side and works great. The main thing is that you want to have at least a slight angle so that air isn't trapped in the radiator.
