TOWPRO from Ridetech for anyone hauling or pulling
Although we specialize in Corvette, muscle car, and hot rod suspension components, we also offer a Premium Towing kit for your Tow Rig.
Our LevelTow kit is an intelligent, self leveling, airsping kit.
We use quality Firestone air springs, an intelligent leveling sensor, self contained tank-less compressor, 1,000,001 mile warranty fox shocks, and weather proof wiring.
Check our your application here
http://www.ridetech.com/store/towpro-kits/
Our TOWPRO kit is an intelligent, self leveling, airsping kit.
I have a 2007 35' Funmover built on the Ford F750 chassis. It is rated for 36000 lbs, but as I tow it only weighs about 27000 lbs. It has heavy and harsh leaf springs on the rear axle. It makes for a nasty ride sometimes, especially on roadways with the expansion joints every x number of feet.
I have long wanted to remove one or some of the steel springs and add in a set of airbags. I am presuming that will take out some of the harshness. Do you have anything that will work in that application?
I will keep you in the loop if my kits extend into heavier duty applications.
