best rear tow hook? new to HPDE
New to roadcourse racing.. Looking to do a HPDE at streets of willow this year with speed ventures.
I see VMS makes a rear tow hook that is cheap and I saw another thread where someone installed it.. The VMS one uses the existing bolts and holes for the exhaust hangers.
Do you think the VMS toe hook would be fine for my uses?
I have seen tow hooks by Benen that look much thicker however you need to drill into the frame. Do I need to take the bumper off to install either of these?
What one should I use??
I put the vms hook on the back of my car and it is very easy to install. Haven't had to use it yet so I can't comment on its durability. I believe that it touches the rear valence so I get an occasional vibration from the exhaust pipes which are stock. There isn't much thread available to shim it with washers to prevent this.
I'm in the process of installing a front hook. Not as easy as it sounds. All air box parts come out. Front valence is in the way to drill the holes. I'll be trying a 90 degree drill setup this weekend to see if that works or not.
Have you tried taping a small piece of foam onto the rear tow hook to dampen the vibration?
Pfadt rear tow hook uses 2 existing muffler hanger bolts to secure it to the framework. If you have some fab skills. Drop the mufflers and crawl up under there and you'll see you have room to attach just about anything.
Dropping mufflers is not required to install a Pfadt hook.
Kevin
Good idea on the foam
I ended up buying the VMS tow hook last night online. I like that it uses the stock exhaust bolts and holes and I don't need to remove the bumper. I looked at the car last night and it seemed like the back bumper would have to be removed yo access the inner part of the back frame to put the bolt down thru drilled holes. Only way around that is if u have a super long drill bit and bolt AMD drill straight up thru both walls
I have Phoenix front and rear hooks. Both very high quality. Don't have to remove the rear bumper to install, but if you have C6 with NPP there isn't a lot of space to work. I know you're not asking, but the front hook install requires front bumper removal. It is not terribly difficult, but something to think about if you decide to install both.
my car is a c5z..
FWIW here is my new thread with the install pics.
https://www.corvetteforum.com/forums...post1588749786
