C4 for B Street
There's no way a C4 will run with a C5. The front negative camber that you can get with a C4 is less than half a degree. A C5 is going to have about 2 degrees and that's the end of that story. Yes an early C4 has more front end grip on tighter courses than a later C4, but on faster courses it isn't as big an issue. To get close to a C5 you're going to need a lot more negative camber in the front end and that's simply not possible.
Bottom line is that the greater negative camber in the front makes a C4 an also ran compared to a C5.
Max G’s
And one other disadvantage a c4 has is the fuel starvation issue when running a lower amount of fuel in corners. You typically have to run @ 1/2 tank or more of fuel in a C4 to prevent starvation. However if you decide on a C4 there is a way to prevent this.
Max G’s
They should just move the C4 down into C street. It's sort of ridiculous to expect it to run with a C5.
I'd look into an S2000 if you're looking at RX-8s. Not as roomy of a car, but similar performance and they don't blow themselves apart constantly. That said a good friend of mine has an RX-8 and his has given him no problems. In fairness, his is sort of beat, and is a total base model. But it runs well (just slow - my C4 pulled away from it when I missed 3rd for 5th, and still pulled away easily).
I wouldn't count on getting the C4 reclassed in Street. The 84-85's have already hit the Street category sundown rule - ineligible to compete nationally 30 years after the manufacturer designated model year. The '89's have 4 years remaining. Time to put them out to pasture.
ST*, I might have to write a letter.
I run with -2.6 front camber. You just have to be a little creative.
Richard Newton
Richard Newton
#33
The object of the game is to win with a legal car. If you don't want to do that don't bother.
#34
Max G’s
#35
That's why everyone gets slower at the Nationals.
Richard
Richard
#36
What would actually happen is that at the Divisionals his competitors in grid would see the car and after the first run if he was even remotely fast he'd be told that his car was obviously illegal and that if he makes a second run he's going to be protested and that he should have "car problems" and not run it any more that day and not to bring it to any significant events looking like that. Someone would offer him a ride and the driver would know he's not going to run the car like that Nationals.
That's actually what happened in the Central division when a person showed up a C4 in the early 90's that had about 2.5 degrees of negative camber because the person had pulled the frame top horns so that he didn't need offset bushings or any of that crap...
Good drivers don't have to cheat, and they don't because they are placed under even more scrutiny than guys back in the pack.
#37
I was thinking I'd keep running mine if C4's moved to C street but that's unrealistic. I may just bring mine out to a few non SCCA events this year.
#38
Max G’s
And to add to all this. A C4 is a tough car to win with vs the newer generations and even newer cars. Most new cars today have good suspension geometry and the traction management systems and computer controlled shocks and etc. But if you can learn to drive and become a good driver, I think you can be successful with a C4. Its about being a good driver anyway right? I suppose you would ask yourself; am I a good driver with a decent car or am I a decent driver with a good car?
#39
SCCA in my area is basically the Miata club of the area. The courses are all tight twisty things with top speeds of under 45mph. After one event I decided t was totally unappealing to me.
I've heard PCA puts on better autocrosses than the SCCA one I went to.
#40
Supporting Vendor
