--LG Motorsports C5/6 HD Rear Tie Rod--
Old 01-14-2015, 01:54 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default --LG Motorsports C5/6 HD Rear Tie Rod--
--RELEASE--
LG Motorsports HD rear tie rod kit is designed for full bump steer adjustment as well as give you a stronger tie rod assembly. Toe changes are done very easy with LH/RH threads at the ends. Bump steer can be adjusted at both the inside and outside locations for even the most radical suspension setups. Inside mount is also offset to give greater clearance for aftermarket coil overs.
LG Motorsports HD Tie Rod
Old 01-14-2015, 06:23 PM
FuriousDonuts
FuriousDonuts's Avatar
Neat- how much additional clearance from the coilover does the offset mount provide?
Old 01-14-2015, 06:39 PM
Former Vendor
A good 1/2" or so.
To --LG Motorsports C5/6 HD Rear Tie Rod--
