How to get Trans Temp on Torque Pro App ?
How can I get my transmission temperature on the Torque Pro App ?
2006, LS2 Coupe, with Manual Trans.
I'm curious as well. I've heard it only comes up on the dic when it's above 275 deg F but you can trick it by connecting a resistor corresponding to that temp to the sensor out put briefly and then switching back to the real sensor output. It'd be cool if you could bypass all that with some software.
