Positive caster vs. negative caster defined
So just to be clear in general automotive terms is POSITIVE like the angle on the front of a chopper bike and NEGATIVE like the front wheels of a shopping cart?
So vettes have negative.
You've got the positive and negative right, but vettes usually run a positive castor of 6.4 deg to 7.4 deg. or thereabouts when you're done getting camber you want.
Thanks.
So to increase caster on one side using UPPER SHIMS ONLY where do I move the shims?
Found more, positive means lower bj is ahead of upper bj.
--Dan
Then I'll go ahead & set my camber where I want & so on.
Once you have that "differential" in the shims done and you keep that differential, the caster should remain equal, no matter where you take the camber, yes?
Video will be up tonight.
A note about washers, if you go to the hardware store you can find a wide range of thickness (.060" - .105") in the same 3/8" washer. I've mic-ed and marked a bunch and can fine tune with these behind the dog bone to set caster.
For shims, I went to 1/8" from the local tire store and can place up to 5/8" on longer studs that I also made. This will take the camber from zero to -3.5. I keep all five shims in at all times and vary between how many are behind or in front of the dog bone. This way the nut doesn't move much when making adjustments.
--Dan
St. Jude Donor '15
image from my website showing caster. basically it's a line drawn from the upper ball joint to the lower ball joint. if the top is behind the lower it is positive. it is ahead, then negative.
I believe so. I only adjust the UCA and leave the camber plates set to max on the LCA. On top, I set caster with washers so they can't fall out and then drop in shims to adjust between low and high camber settings.
--Dan
--Dan
I should do that with the washers & get back a lot of 2mm shims.
--Dan
Froggy please let me offer a bike based view of caster, or self centering, or trail, as it is commonly called on Bikes.
If you draw a line down the steering axis and mark where that line hits the ground. Then drop a plumb line down intersecting the centerline of the front hub. The second line must hit the ground BEHIND the first line. That distance is called "trail" or kingpin inclination, or caster, It encourages/requires the steered wheel to follow the aiming point, or "self center".
If, on a jump, the rear wheel hits first, then the front or steered wheel will always come down with the correct geometry and self center....in the forward direction.
If however, the bike lands on the front wheel, AND the rider/bike combination is tilted too far forward, THEN the line of the steering axis will hit the ground BEHIND the centerline of the front wheel, STILL promoting "self centering", BUT now causing the front (steered) wheel to try to turn completely around (like a shopping cart caster)...............and in the process, usually depositing the rider (catastrophically) on the ground, sometimes with the bike on top of him. I use this rather graphic illustration because it helps people remember what happens when a "caster" self centers
St. Jude Donor '15
kingpin inclination and caster are not the same angle when referring to cars. this is kingpin inclination or steering axis inclination
