have you built a rear diffuser yourself? post it up!
Old 02-06-2015, 01:48 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default have you built a rear diffuser yourself? post it up!
Interested to see how some of you made yours.
Old 02-07-2015, 02:15 AM
FRC Z51
FRC Z51's Avatar
In for the updates
Old 02-07-2015, 11:22 AM
crimlwC6
crimlwC6's Avatar
I'll have some pics of a setup in a couple of weeks
Old 02-07-2015, 01:17 PM
ratt_finkel
ratt_finkel's Avatar
Ditto. It's not too hard.
Old 02-08-2015, 10:33 AM
VGLNTE1
VGLNTE1's Avatar
Lol. I can't wait to critique
Old 02-12-2015, 03:41 PM
smellya
smellya's Avatar
Old 02-12-2015, 03:52 PM
ratt_finkel
What questions do you have about the build and I can try and point you in the right direction...
Old 02-12-2015, 05:04 PM
VGLNTE1
VGLNTE1's Avatar
Just waiting for yours to be Done. I know the angle, where I want it, need it, ect...but like to see how others have made mounting poings, ect...
Btw...your cage looks crazy
Old 02-16-2015, 10:55 AM
chuntington101
chuntington101's Avatar
I'm expecting a fan assisted blown diffuser that maintains constant ground clearance and acts directly on the wheels (rather than the chassis).
If you want some info on the above let me know. A guy was building one for a Elise on another forum. They reported amazing results from it.
Old 02-16-2015, 03:15 PM
jstout
jstout's Avatar
Chattanooga Area Events Coordinator
I'm on here because I race in ST2 and can't have any more hp, so I am looking at any other opportunities to lower my lap times. Jerry
Old 02-16-2015, 05:18 PM
jtmck
jtmck's Avatar
Ridetech soon to be available, Series 3 race suspesion.
I have run the development car for about three years.
STS in 2011/12
ST2/TT2 2013
TT3 2013/2014
1998 C5 Corvette #44
bret@ridetech.com
Give Bret a call and tell him you are interested.
Jim M.
Old 02-17-2015, 12:55 AM
VGLNTE1
VGLNTE1's Avatar
Your anyway have a wing and splitter?
Old 02-17-2015, 05:37 PM
jstout
jstout's Avatar
Yes, wing, splitter with undertray, and louvered hood. Thanks. Jerry
Old 02-19-2015, 02:00 AM
chuntington101
Here is the thread for the blown diffuser for anyone that's interested. They recon it was making about 1000lbs of downforce at low speeds!
http://noble-speed.com/showthread.ph...assis-supercar
Old 02-19-2015, 08:01 PM
383's Avatar
Im still waiting on registration. can you post the pics?
Old 02-20-2015, 10:22 AM
chuntington101
There a quite a few pics and it's more the technical information that's the good bit. Best waiting for the reg to go through and then Read the thread. It's good.
Old 02-20-2015, 01:48 PM
el es tu
el es tu's Avatar
most of you all have seen mine but for those that havent:
front undertray (the finish is straight from the mold - probably wont get clearcoated since you cant see it):
The plan is to install everything this spring...
To have you built a rear diffuser yourself? post it up!
Old 02-21-2015, 04:10 PM
VGLNTE1
VGLNTE1's Avatar
Nice. Did you mold the cf yourself?
Old 02-23-2015, 08:46 AM
el es tu
el es tu's Avatar
Yep main body and fences are all CF and kevlar reinforced plastic from a single fiberglass mold so everything can be replaced. The gurney, mounts, and front undertray came from lost process foam molds.
Its not a difficult thing to do (just takes a little practice to learn how you need to work and plan things out) and not extremely expensive if you have a local supplier; the online stores bend you over on their pricing for cf - 50 to 80 bucks a yard is a rip off (you should pay around 30 to 35 for 6oz and 40 to 50 for 11 to 12oz carbon; kevlar should be the same or a few bucks cheaper than carbon). As far as resin goes, smooth-on brand laminating epoxy works well and is MUCH cheaper than West system stuff...
Id definitely start with fiberglass and polyester or polyvinyl resin (should only be 30 bucks a gal) just to make simple objects as practice before going to more expensive materials like epoxy and carbon.
Old 02-23-2015, 07:14 PM
383's Avatar
Not too hard unless you try to mold/layup a C6 headlight bezel...... Now I know why they are 1500 a set.
Quick Reply: have you built a rear diffuser yourself? post it up!
