Outside rear view mirror needed
I searched & didn't find much, where do I buy one of these - just the glass?
They have some on Amazon that you stick on top of the damaged one for $20, but I'm not sure what the quality is.
Of course mine died at 55k so I guess oem and quality should not be words next to each other.
http://parts.nalleygmc.com/products/Chevrolet/2001/Corvette/GLASS-InsideOutside-Rear-View-Rear-View-Mirror---Inside--Outside/2628391/12455610.html
I'm guessing you mean the driver side, electrocromatic one? Mine's dead as well with 66k on the car. I've found the glass online but it's fairly spendy at ~$260 or so. There also appears to be a standard glass without auto-dimming that's just under $100. I'm a bit torn on whether to roll the dice with the "right" part or save a couple bucks and go without the auto-dimming...
http://parts.nalleygmc.com/products/.../12455610.html
That's what I'm trying to avoid price wise.
Agreed. I was a little shocked to see the price tag associated with the direct replacement. I found some cheaper options from car-part.com but I'm not sure that's a great option either as they're probably just closer to the (inevitable) failure point.
I suspect that the non-dimming mirror should be a direct replacement and is quite a bit cheaper:
http://parts.nalleygmc.com/products/.../12530715.html
I've seen the stick on solution from Amazon/eBay that you referenced. I suspect that it would work reasonably well but, between the mirror and adhesive, it seems like it wouldn't sit as flush as the stock mirror. I expect that the result would be something that would bug me every time I glance to the left.
With the defrost, I'm in socal so that's not much of a problem either.
I may try the stick on for 20 bucks what's the harm. If it sucks I'll go more expensive.
