C5Z rotor ?
Old 02-10-2015, 01:58 PM
JUSTCRZN
Support Corvetteforum!
JUSTCRZN's Avatar
Default C5Z rotor ?
Hi, I have a 04 C5Z and have a chance to pick up an almost new set of 08 C6 non Z51 rotors for a good price to be used as spares in case one cracks at a track day. The part numbers are different, but they measure out the same. Am I missing something??
Thanks for any info
Old 02-10-2015, 03:30 PM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
Thanks for any info
Those should work fine for you. C5, C5 Z06, and C6 base have interchangeable rotors.
Old 02-10-2015, 04:42 PM
CHJ In Virginia
CHJ In Virginia's Avatar
They will work just fine. Did you measure the thickness and make sure that they are above discard spec ? If they are almost new it probably will not be a concern.
Old 02-10-2015, 05:19 PM
JUSTCRZN
JUSTCRZN's Avatar
Thanks for the info. They only have about 6,000 miles on them.
Old 02-12-2015, 11:11 AM
waddisme
waddisme's Avatar
About all I have used the past 3 yrs are the C6 rotors. The C5s are mostly gone. I scour the C6 For Sale for deals.
To C5Z rotor ?
Quick Reply: C5Z rotor ?
