Continental GT-O and GT-R slicks - what temps
Anyone know what are the Hoosier specified target temps that these tires like the best?
Usually there is a brochure re: tire safety & care that spells it out, but they forgot to send me one.
Would these be considered Hoosier's "GT Tire"?
https://www.hoosiertire.com/GTpsi.HTM
This describes a 20 psi cold pressure, 30 psi hot target, a 20 degrees being the preferable gradient across the tire, a 175-220 degree optimal temp range, and a front to rear difference of no more than 25 degrees.
After one of my last sessions I recorded these values:
But I don't think I'm pushing them hard enough. BTW the columns with no headings are the differences between the "perfect" centre temp for an even gradient, and measured. Since these are all well under +/- 5 degrees, I think the 30 psi hot target is right (this is what I set the tires to immediately after each session all day long.)
