c6 rear 18" wheel options
Old 02-17-2015, 09:54 PM
furiousox
furiousox's Avatar
Default c6 rear 18" wheel options
I did an extensive search and found a few threads with inconclusive result
It seems the selection of 18" wheels with correct offset on the rear are quite limited. The C5Z rear wheels and c6Z front wheels seem to stick out too much on a narrow body c6 like mine
Can I buy a set of front c6 narrow body (18 x 8.5 I believe) wheels and put them on the rear? It looks like I can fit up to 265/275 tires on these wheels? Will that be enough traction?
My fronts will remain stock size
Any other inexpensive 18" wheels I can consider on the rear?
Thanks in advance!
Old 02-18-2015, 02:34 PM
hungryhippo
hungryhippo's Avatar
Tsw's are made for c5 and c6. They are flush with the fenders. A 275/40 or 295/35 should not rub.
Old 02-18-2015, 04:58 PM
furiousox
furiousox's Avatar
Thank you! I was hoping for more affordable options via Oem wheels, however, is that not possible?
Old 02-19-2015, 01:00 AM
hungryhippo
Not that i know of. I have tsw's for street and ccw for track. You really need a full set because the fronts are too narrow. Why not just stay with the stock 18/19" wheels?
Old 02-19-2015, 09:35 AM
Chevy Nick
Chevy Nick's Avatar
It's an expensive hobby.
To c6 rear 18" wheel options
Quick Reply: c6 rear 18" wheel options
