C5Z track alignment question
#41
Hey guys, I wanted to give an update on my self-alignment experience.
So I bought some tools, and attempted over the course of 2 days, messing with my alignment and measuring and adjusting.
Since I do have a track day for the next two days, I decided it was smart to have my work checked and corrected.
I chose Les Schwab nearby because I recently bought new tires through them for the vette and they seemed genuinely nice.
So for my first alignment, (and take note of what i started with in my first post). This were the 'before' results.
Camber
Front left: -2.1
Front right: -1.6
Caster
Front Left: 6.4
Front Right: 7.6
Toe out:
Front Left: 0.01"
Front Right: 0.03" (1/32")
Camber
Rear Left: -.8
Rear Right: -1.1
Toe In:
Rear Left: .16"
Rear Right: .14"
Thrust angle: .03º
^that was my results. I dont know if its better or not then what i started with, but it was a learning experience. I thought I shimmed my tires enough for my driveway slope, but i guess not. it angles to the right by about half a degree all across.
After les schwab was done with my car:
Camber
Front left: -1.5
Front right: -1.6
Caster
Front Left: 6.8
Front Right: 7.0
Toe out:
Front Left: 0.03" (1/32")
Camber
Rear Left: -.9
Rear Right: -.9
Toe In:
Rear Left: .08"
Rear Right: .08"
Thrust angle: .01º
I think their results were much more accurate to what I originally requested. I did ask for a tad more front camber as I kept hearing that 1.3 by pfadt specs were quite conservative.
Camber
Front left: -2.1
Front right: -1.6
Caster
Front Left: 6.4
Front Right: 7.6
Toe out:
Front Left: 0.01"
Camber
Rear Left: -.8
Rear Right: -1.1
Toe In:
Rear Left: .16"
Rear Right: .14"
Thrust angle: .03º
Camber
Front left: -1.5
Front right: -1.6
Caster
Front Left: 6.8
Front Right: 7.0
Toe out:
Camber
Rear Left: -.9
Rear Right: -.9
Toe In:
Rear Left: .08"
Rear Right: .08"
Thrust angle: .01º
#43
Received 8,956 Likes
Camber
Front left: -2.1
Front right: -1.6
Caster
Front Left: 6.4
Front Right: 7.6
Toe out:
Front Left: 0.01"
Camber
Rear Left: -.8
Rear Right: -1.1
Toe In:
Rear Left: .16"
Rear Right: .14"
Thrust angle: .03º
Camber
Front left: -1.5
Front right: -1.6
Caster
Front Left: 6.8
Front Right: 7.0
Toe out:
Camber
Rear Left: -.9
Rear Right: -.9
Toe In:
Rear Left: .08"
Rear Right: .08"
Thrust angle: .01º
Camber
Front left: -2.1
Front right: -1.6
Caster
Front Left: 6.4
Front Right: 7.6
Toe out:
Front Left: 0.01"
Camber
Rear Left: -.8
Rear Right: -1.1
Toe In:
Rear Left: .16"
Rear Right: .14"
Thrust angle: .03º
Camber
Front left: -1.5
Front right: -1.6
Caster
Front Left: 6.8
Front Right: 7.0
Toe out:
Camber
Rear Left: -.9
Rear Right: -.9
Toe In:
Rear Left: .08"
Rear Right: .08"
Thrust angle: .01º
Bill
