Track preparations?
PM me if you want to chat before your event as we're probably neighbors. I have another friend in P-ville with a C7 Z51 as well that I've been instructing. I normally track a C6Z but ran my C7 Z51 a few times last year before trading it for the C7Z.
I'd stick with the stock pads for now. I got 2 days at VIR and 2 days at Summit Point before I needed to replace them and that was running in the instructor group. However, unlike my C6Z you do have to watch the rears as well as the fronts. One more day at Summit Point and the rears were down to the backing plates (I had replaced the fronts the day prior). I never had any issues with brake fade.
I would suggest flushing the brake fluid with Castrol SRF but I consider that cheap insurance and optional.
More importantly, get an alignment done before you go to the track. My factory alignment was pretty far off (0 deg camber in the LF) and it pretty well tore up the LF tire in 2 days at VIR. I did swap fronts though and got another 3 days at Summit before I had to replace them. My friend got an alignment first after my experience and his tires are fairing much better. I daily drove the Z51 and plan to do so with the C7 Z06 but in both cases I had them do the track alignment so we'll see how the wear evens out. I can recommend a shop in Leesburg if you want to do this.
Other than that just make sure you know how the PTM modes work. It took me a couple sessions to realize I was turning the nannies back on instead of off. The C7 is a phenomenal platform and a lot of fun on track.
1. Can a reasonably skilled owner swap break pads in/out by himself, or does it need to go to the shop?
2. Can you please name the reliable alignment mechanic in Purcellville/Leesburg or nearby who can do C7 work?
3. Looks like my car doesn't have competitive drive mode or PTM. I believe that is standard on a Z51 but optional on the 2LT I have.
4. All forum friends, please excuse my ignorance, but what's a "nannie?"
Cheers!
A "nannie" is an electronic control system that can over-ride the driver's inputs. The easiest example is traction control, where the computer will reduce the throttle when it senses wheel-spin, regardless of what the driver is doing to the throttle pedal.
More subtle is dynamic handling, where the system sees the car getting into an oversteer or understeer condition and will apply the brakes on one corner of the car to bring the car back to eliminate the over/understeer. Sounds good, but it's killer on brakes and can intrude on what the driver is wanting to do.
Some of these system's parameters can be modified via your drive mode selector; your owner's manual can give you some idea, but the C7 forums will do a lot to tell you the details.
This isn't a complete list (I left out ABS, for example, as it's not normally considered a "nanny"), but gives you an idea.
HTH, and have a good one,
Mike
Mike
Thanks, neighbor! A couple of follow-on questions:
Cheers!
Cheers!
2. Curry's in Leesburg is where I go when I can't do it myself.
3. Ah, I'm guessing you didn't get the MR shock option and I believe that is required for PTM.
4. ABS/traction control/active handling. You'll still have that even without the MR shocks but it just isn't as adjustable.
Former Vendor
Thanks, Matt. Can I leave any of those high performance brake fluids in the car for DD, or do I need to change it back out after a track event? My preference is to find a fluid I can leave in for daily driving (same with brake pads, BTW) and avoid the change-over every time I attend a track event.
-Matt M.
1. Assuming it's a Z51 the pads are easy, no clue on a base C7. I did mine in the paddock. In fact bring a set with you and if you need to swap them I'm sure there will be folks to help. The biggest issue was making sure you had the right size punch to pop the retaining pins out.
Poor-sha: Can Curry's do other Corvette work, such as reliable oil changes, brake pads, etc? Do you know of a high-quality "speed shop" or other in the local area who specializes in Corvettes and/or can reliably service a C7?
Thanks!
Thanks!
Call over there and talk to Andrew, he's the manager who I first met at the track.
Also, come out to Summit Point with the Audi Club in a couple weeks. I'll have my C7Z there and the head instructor is picking his up this week and bringing it as well. His is an A8 Z07 and mine is an M7 Z06.
Yup. They're not really a speed shop but more a local shop that does good work and most of them are racers. My buddy uses them for pad and oil changes on his C7 Z51 (I do them myself).
Another question; this one on helmets. I see the minimum rating standard required for SCCA and/or Summit Point. But I can't figure out where to buy one, especially not knowing what size to get, or what type and manufacturer. Any suggestions?
Thanks!
Thanks!
Try OG Racing in Sterling, VA. Great shop with a knowledgeable staff. They have a ton of SA2010 helmets from various manufactures in stock. It's nice to try various fits/sized on before you buy.
Received 8,928 Likes
Helmets have to fit tight around the crown of the head, and the sides should force your cheeks inward so you feel like you will bite them if you close your jaw. The top of the helmet opening should fit tightly across the brow (just above the eyes). The chin strap needs to fit tight under the chin and toward the neck. When trying a helmet it should be somewhat hard to put on. Once on have somebody grab the front of the helmet and try to rotate the front upwards and off your head. Then repeat from the backside to see if the helmet rolls forward off your head. There have been numerous accidents where empty helmets with chin straps still fastened are sitting on the ground near a car that has been in a serious rollover incident.
I like the Impact Helmets. They are made Bill Simpson's new company since he is no longer associated with Simpson. OG doesn't sell those but they do sell a number of good brands. If you don't mind spending in the $1K to $3K range then look at Stilo helmets. I believe all of the Hendrick teams use them now. I know that Earnhardt Jr, Johnson and Gordon do. When you try on even their lowest cost helmet it practically spoils you. They have ear muffs inside to reduce outside noise, locations to place speakers inside the helmet so you can hear an intercom or crew chief radioing you and they are pretty light. http://stilo-usa.com/
Bill
#33
Thank you, both. I'll head out there tomorrow. I visited their website and they have enough shapes, styles, options, and manufacturers that I can't discern applicable/appropriate from exorbitant/wrong class. I look forward to trying on a few and discussing with the employees there.
#34
+2 for OG. Try a bunch on and see what fits you best. The staff there will know what to look for as well.
#35
Just a couple thoughts.....if you are only going to the track to try things out, I wouldn't go to extreme right off the bat. I would use the factory allignment and change the oil and upgrade the brake fluid to a DOT 4. When I first started I just used Prestone DOT 4 fluid, it has a 510* dry boiling point, and you can get it anywhere (including Wally-world) for less than $4 for 12 oz. Buy 3 of those and you can easily bleed the full system. I doubt you will need more than that for your first time out. Just my $0.02. If you get really into the track, then start to consider the $20-$60 per quart brake fluids that all have dry boiling points of 590* or higher.
#36
Speaking if helmets - it's all about the fit. Here's an article I wrote about helmets last year.
Keep in mind that paying more money does not get you a better helmet. It might get you a lighter weight one - but not a better one.
Both the Snell and the FIA tests are Pass/Fail. There are no tests to prove one helmet is superior to another. I have a standing offer to retract this statement if any helmet manufacturer can produce results by a testing lab that demonstrates differently. So far no one has.
Just take the car and drive it. Do not spend money on any modifications. If you feel the need to spend money hire a driving coach. Right now the car is a lot faster than you are.
I guarantee you that John Heinracy or Ron Fellows can make your car go faster than you can. When you can match their lap times then you might consider an aftermarket part. Might.
Richard Newton
Richard Newton
#37
My thanks again for the continued good advice. No mods intended in the immediate timeframe. I'll use a higher-grade brake fluid, change the oil, and get a decent helmet. We'll take it from there after that.
#38
I'm out here near you guys in Round Hill.
Curry's is a good shop that I trust but man are they expensive. I've been using Mach V Motorsports in Sterling for alignments, tire swaps and yearly track inspections. Prices are much more reasonable. They are mostly a Subaru, Scion etc shop but will work on anything and are good people. They usually sponser one of the NASA events too so I like to give some back.
Ed Butler
C5Z06 NASA TT3
Ed Butler
C5Z06 NASA TT3
#39
Well here's an interesting twist. I went to one of the local automotive maintenance shops (to remain nameless) that specializes in SCCA and Corvettes to make an appointment for an oil change and brake fluid replacement. I know these guys and they are highly credible (at least to me!) Their recommendation: with only 2,000 miles on the car, leave it completely stock for the first FATT outing. The car/engine is built to run hard, and an outing at FATT will provide an opportunity to identify whether the OEM oil, brake fluid, etc is sufficient. FATT does not put enough demand on the car or any components to require fluid changes at only 2,000 miles.
Thought? Comments?
Thought? Comments?
