Big Brake Kit ROTOR RINGS suppliers
Old 02-24-2015, 04:51 PM
jd86L98
jd86L98's Avatar
Default Big Brake Kit ROTOR RINGS suppliers
Anyone have experience with these Rotor Rings? The Brembo rings are ridiculously expensive.
http://www.racingbrake.com/Rotor-Rin...ent-s/4355.htm
Old 02-26-2015, 03:57 PM
jlutherva
jlutherva's Avatar
About 1/2 the price of Brembos! I've got a spare set of Brembo fronts (380mm) but might need a rear set this season.
Jim
Old 02-26-2015, 04:58 PM
0SpeedFreaksUSA
Former Vendor
SpeedFreaksUSA's Avatar
Location: Reno/McCarran, NV - Bay Area, CA - NW Burbs of Chicago, IL
I'm assuming you need the 355x32mm but please clarify what size you're looking for. After some of the experiences I have witnessed with rotors from that brand I would urge you to reconsider. If you want to save some money AND keep a quality set of rings on your Brembo hats then go for the Stoptech AeroRotor rings for about the same price as the RB rings. The design, construction and metallurgy of the stoptech ring is superior to RB ring and they will last a lot longer from what I have seen. We have used them on several of our own Brembo kits and supplied to many others who track their car often and don't want to pay for the Brembo rings. I can say that for sure that 328x28mm, 355x32mm and 380x32mm are direct fit onto the Bembo hats that use those rotor sizes but please confirm first. If needed I can pull the technical drawings to double check fitment.
Please let me know if I can help.
-Matt M.
Old 02-27-2015, 10:15 AM
jlutherva
jlutherva's Avatar
Thanks Matt, appreciate the advice. I have the Brembo GT BBK. The rear rings are 345 mm.
Jim
Old 02-27-2015, 01:11 PM
0SpeedFreaksUSA
Former Vendor
Jim
345x28mm? I'm 99% sure that size fits just fine as well but let me confirm for you.
If so and you are interested, we have them on sale for 15% off with free shipping right now. We can also spec them with the race hardware to allow a little more float at no additional charge
StopTech AeroRotor Replacement Race Rotor Slotted Left 345x28mm
StopTech AeroRotor Replacement Race Rotor Slotted Right 345x28mm
-Matt M.
Old 02-27-2015, 02:15 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Remember there is more that goes into a rotor than just price.
That might be a good option and probably not bad to try, but you should also keep a record of how long they last, and also the other parts that are affected like pad wear and caliper rebuilds.
That might not sound like all of those would go together, but the vanes in the rotor, the angle, and the number of vanes do matter on cooling and how much air is being pumped through the entire assembly and thus can effect pad wear and caliper life, not only the life of the rotor.
In some cases, like our early TransAm race car days, the rotors didn't matter and there was no point in buying expensive rotors as you were lucky if they lasted a race, much less the entire weekend. The newer, and larger, brakes found on the endurance cars do matter and you might spend a little more for a rotor that would last you 8hrs vs something half the cost that might only last 2 hrs.
Just something to think about.
Old 03-01-2015, 09:39 AM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Did we confirm that those fit the rear of the Brembo GT kit? With as little as the rears wear on a C6Z I'm willing to try a non-Brembo rotor.
With the fronts I got 70 sessions on the last set of 350x34 72-vane Brembo rotors. They still haven't cracked but I have started wearing through the grooves
Old 03-01-2015, 11:23 AM
leadville1
leadville1's Avatar
I've given Racing Brakes two attempts and both have come up pretty bad. I bought them instead of Stoptech's for my Stoptech kit and they cracked within 4 days on the track. I threw them away and went back to Stop Tech, with no regrets.
Old 03-01-2015, 03:27 PM
63Corvette
63Corvette's Avatar
-Matt M.
Hi Matt, that's good to know. I have run Stoptech BBK on my street 04 Z06 since 2006, with a few track events per year, and STILL run my original Stoptech rotors without any problem. I feel a little better now
Old 03-01-2015, 09:16 PM
2 GTOs
2 GTOs's Avatar
St. Jude Donor '11-'12
I believe you can contact coleman and send them your old rings and they will make new ones. They keep the specs on file for reorders.
This is what they told me, but I have not tried them yet.
Old 03-01-2015, 11:10 PM
db2xpert
db2xpert's Avatar
Used Coleman for a dozen years, Many orders, both C5 Z and C6 Z.
Old 03-02-2015, 01:44 AM
jd86L98
jd86L98's Avatar
Great to know!
Old 03-02-2015, 01:48 AM
jd86L98
jd86L98's Avatar
-Matt M.
The AERO Rotors sound like a good alternative.
Old 03-02-2015, 01:49 AM
jd86L98
jd86L98's Avatar
Brembos on the front and a Stoptech rotor on the rear might be the way to go.
To Big Brake Kit ROTOR RINGS suppliers
Quick Reply: Big Brake Kit ROTOR RINGS suppliers
