ZO6 brakes on a Z51
ZO6 brakes on a Z51
I am wondering if anyone knows if Brembo brakes off of a C6 ZO6 will fit/work on a Z51? I know that rotors and rims will need to be changed which is fine, I just need to know if the calipers will bolt up using the Brembo brackets.
I found this but this is for ZO6 brakes not brembo. thanks
https://www.corvetteforum.com/forums/...51-rotors.html
yes, the dimensions are the same
keep in mind that most of the brembo kits require shaving the lower control arm.
There should be a few threads on this, buried in the forum
