Bilstein Sport or HD or Koni FSD
Is it okay to run the bilstein sports on stock ride height cars or is hd a better choice? The reason im asking is because many times bilstein sports are designed for lower cars.
Also has anyone tried koni's fsd for track, autocross, or hillclimb? Im interested in the special blowoff valving as the car is being setup for extremely rough surfaces - the concern with these shocks is if theyre too soft in order to cater to cruising rather than performance (koni states that these are not for c6 z06 - likely the rear shocks arent set up stiff enough for the 782 spring ).
btw current spring rates are 531 front 657 rear
Thanks!
Thanks!
The FSD's are a nice street shock but aren't what you're after if you want a good performing setup for autocross or the track. The Bilstein's are very close in valving to the 2004 Z06 shocks in the front and a bit different in the back, but they are close enough that unless you have a very calibrated bum you wouldn't know the difference.
The Bilstein's are the same length as the stock shocks.
ive heard the bilstein HDs are stock length but the sports are supposed to be shorter... could you clarify which set youre referring to?
Thanks!
Thanks!
I was asking the same questions as you until I got these. Never looked back and have been happy ever since.
https://www.corvetteforum.com/forums...it-s-back.html
Supporting Vendor
Or you could get real shocks that allow you to fiddle with the feel, and reaction of the car.
I'd not recommend any of the above, you can do so much better. Koni Sports, Ridetech HQ's but rebound adjustable, both with killer warranties. Yes they cost more than non-adjustable, but they are worth it for someone trying to go fast.
FSD's are not what you want. All shocks unless they really are cheap crap are digressive. I have Ridetech, Koni, Bilstein damping curves all. I have both Ridetech and Koni's on my two cars and I run them, particularly in front at levels far beyond what a Bilstein has to offer. And yes I drive them both on the street. And I live in western PA, where the roads are not glass smooth (we have real winters here, frost heaves galore right now too).
Nobody thinks of this but should. Rebound damping does things like makes the car take a set. Most gearheads, like that to happen pretty quickly. We typically want more rebound damping than the average bear. Rebound damping also controls the roll and pitch rate. Good shocks can slow the roll tremendously at the same time the car changes direction more quickly. Shocks matter, a lot, to get the car to feel and act the way we want. They are very much about feel. Having shocks that you can't do anything with isn't wise. We are different people, we like different things. A tire change can dull the car's reactions, change the turn in balance, etc. Shocks help tune that (as one example).
__________________
Sam Strano
Strano Performance Parts
www.stranoparts.com
814-849-3450
More options than any other single company out there. More parts than any other single company I know: Brakes to Safety, Wheels to Exhaust. Suspension to Air Filters: Girodisc, Hawk, Raybestos, Essex Racing/AP, Ferodo, Wilwood, Penske, Koni, Borg Motorsport, Ridetech, Viking, After Dark Speed, Hotchkis, Bilstein, KW, Forgestar, BC Forged, Forgeline, MRR Wheels and on, and on, and on it goes.
Sam Strano
www.stranoparts.com
814-849-3450
