Homemade slip plates - got a pic?
Froggy,
I use 2 greased 12x12"x3/8" steel plates because:
1) steel supports weight better less flexing so plates stay flat and grease allows movement.
2) they are perfect size for 12x12x1/8" floor tiles used to build up plates for flat floor.
I think I'll invest in some hubstands the next time I need to do all this.
This is what I use with dielectric grease between. easy to store away and stand up to multiple use.
http://www.bedbathandbeyond.ca/store...FRSIfgodlZQAFg
I use pairs of 1/16" thick steel squares with wd-40 between them. Sand or salt sounds like something I may try. Less messy than grease or oil. Those plastic cutting sheets look like they may work well too and much easier to put away than a stack of steel with grease on it.
I use two linoleum tiles with a thin layer of playground sand in between. Playground sand is a very fine grain. Works great and is less messy than grease or oil. I take 8 tiles and a water bottle full of sand to the track.
