Tire Temperature Measurements
What type of instrument do you use? I pitted next to a guy several years ago at Sebring that had a really cool instrument that allowed you to go around the car in a certain sequence and measure and record inner, middle and outer temperatures and review them later.
Thoughts?
Jim
Thoughts?
Jim
Thoughts?
Jim
Thoughts?
Jim
I bought it used kind of expensive new
here is a link to a vendor http://www.ogracing.com/longacre-sta...mory-pyrometer
here is a thought
Thoughts?
Jim
Thoughts?
Jim
http://www.harborfreight.com/5-in-1-...ter-98674.html
In addition, this has a dB sound meter. I'm curious to see how accurate this is as I compared to the sound box between corners 5 & 6 at Laguna Seca.
I have the Intercomp like that. This year I am using it every event as I am changing alignments with new tires.
If you buy one without memory make yourself some forms so that if you or a buddy do it you always read in the same order in-out or out-in and also same corner rf/rr/lr/lf or whatever.
Then you can analyze later.
Needs to be done FAST & IMMEDIATELY.
I use the same Longacre Pyrometer as pictured above, and may have been the guy next to you at Sebring.
One thing I have found, at some tracks they are not that much use for HPDE use.
Sebring: You come down the "long" back straight, slow around 17 to make the pit, slow way down pit lane as its not a race then read temps, tends to skew the results.
Daytona: Would not even let me hot pit to take temps.
Jim, Here is what I have
Thanks,
Jim
I'll mostly use it VIR, Rd. Atlanta and Barber. These tracks have an acceptable hot pit area. VIR in particular has Roller Coaster and Hog Pen turns just before the pits.
Jim
I've used a Longacre like Ernie's for 15 years.
We take temps and adjust pressures in qualifying in mid session in the hot pit. Running a cool down lap at the end of a session won't give you very good readings.
