AiM Sport Data Loggers & Dashes
Former Vendor
St. Jude Donor '13
EVO4 Data Logger w/ MXL Dash display
Combine the power of AIM's EVO4 Data Logger, with the clear and easy to read MXL Dash display.
The AIM EVO4 Data Logger is a compact, professional-level modular datalogger with integrated GPS. Easy to setup using the included Race Studio 2 software, the EVO4 samples data directly from many modern ECU's, or directly through 5 analog channels, 2 speed inputs and a dedicated RPM input (additional channels can be added through AIM CAN expansion accessories). An integrated three-axial accelerometer records cornering, braking and acceleration forces, while the integrated GPS provides precise lap timing and track position analysis.
Includes the popular MXL Dash to instantly display important data to the driver. The lightweight, aluminum bodied dash is backlit and water resistant for use in all conditions. Features a fully customizable display, 6 alarm LED's, and 10 LED shift lights.
Package Includes:
EVO4 Data Logger, MXL Dash, GPS antenna, USB cable, RPM cable, Serial+CAN cable, Race Studio 2 software.
Integrated GPS & tri-axial accelerometer
• Connect directly with the vehicle ECU for additional data
• 5 Analog-channels, & 2 designated Speed-channels
• External Power
http://www.xplosiveperformance.com/-...ay_p_3753.html
EVO4 Data Logger
The AIM EVO4 Data Logger is a compact, professional-level modular datalogger with integrated GPS. Easy to setup using the included Race Studio 2 software, the EVO4 samples data directly from many modern ECU's, or directly through 5 analog channels, 2 speed inputs and a dedicated RPM input (additional channels can be added through AIM CAN expansion accessories). An integrated three-axial accelerometer records cornering, braking and acceleration forces, while the integrated GPS provides precise lap timing and track position analysis. EVO4 can also be connected to the AIM Dash of your choice to allow for real-time display of all of your data.
Includes: EVO4 Data Logger, GPS antenna, USB cable, RPM cable, Serial+CAN cable, Race Studio 2 software.
• External Power
http://www.xplosiveperformance.com/-...er_p_3754.html
MXL2 Dash Data Logger
The AiM MXL2 Dashlogger offers an attractive and easy to use interface that is perfect for amateurs and pros alike. By acquiring and displaying data from your ECU, internal accelerometer & gyro, and from the included GPS Module, information is always at hand! The high contrast LCD screen features a white or red backlight that can be changed conditionally and stays at an optimum brightness level with an ambient light sensor. The display, with a black-to-white contrast ratio nearly double of earlier units, can be custom defined with up to eight different pages, and numerous page styles featuring anything from vehicle data to a live track-map. The compact dash also features 6-different alrm LED's that can be custom programmed to your specific conditions, and an integrated 10-LED shift-light with customizable color-LED's.
Finally, like many AIM systems, the MXL2 is limitlessly expandable using the built-in CAN bus. Easily integrate accessories such as a SmartyCam camera system, or Lambda controller. Configuration is easy through the included Race Studio 3 software from AiM, and the dash can easily be accessed through the integrated WiFi connection.
Included:
• MXL2
• 37-pin standard harness
• GPS05 Module
• USB Cable
• Software CD w/ Race Studio 3
• ECU Connection: Capable of acquiring data directly from the vehicle's ECU.
• Analog & Digital Inputs: 8 Analog inputs record up to 1000x per second each. 6 Digital inputs are also included.
• GPS Module: AiM's powerful GPS05 module is included in the kit for accurate lap-time and track position data
• Secondary CAN-line: CAN2 line manages data from additional modules, such as ABS, traction-control, etc.
• Internal Accelerometer & Gyro: Internal 3-Axial accelerometer and a gyroscope for crucial vehicle motion data.
• Math Channels: Configure the dash to immediately display Math Channel values, such as brake bias or a calculated gear.
http://www.xplosiveperformance.com/-...er_p_3755.html
Solo DL, with the included OBDII connecter
http://www.xplosiveperformance.com/-...er_p_3677.html
AiM SmartyCam HD
http://www.xplosiveperformance.com/-...HD_p_3679.html
Package Includes:
• External Power
EVO4 Data Logger
• External Power
Included:
• MXL2
• GPS05 Module
• USB Cable
AiM SmartyCam HD
Former Vendor
St. Jude Donor '13
Package Includes:
• External Power
EVO4 Data Logger
• External Power
Included:
• MXL2
• GPS05 Module
• USB Cable
AiM SmartyCam HD
Package Includes:
• External Power
EVO4 Data Logger
• External Power
Included:
• MXL2
• GPS05 Module
• USB Cable
AiM SmartyCam HD
Former Vendor
St. Jude Donor '13
Package Includes:
• External Power
EVO4 Data Logger
• External Power
Included:
• MXL2
• GPS05 Module
• USB Cable
AiM SmartyCam HD
Package Includes:
• External Power
EVO4 Data Logger
• External Power
Included:
• MXL2
• GPS05 Module
• USB Cable
AiM SmartyCam HD
Former Vendor
St. Jude Donor '13
Package Includes:
• External Power
EVO4 Data Logger
• External Power
Included:
• MXL2
• GPS05 Module
• USB Cable
AiM SmartyCam HD
Package Includes:
• External Power
EVO4 Data Logger
• External Power
Included:
• MXL2
• GPS05 Module
• USB Cable
AiM SmartyCam HD
Former Vendor
St. Jude Donor '13
Package Includes:
• External Power
Package Includes:
• External Power
Lets say I want to run this as my dash. E38 GM ecm and stand alone harness. Old tko transmission.
Can I set it to display rpm, mph, oil p, oil temp, coolant temp and volts?
Can I set to warn on rpm, set a low oil p, and high oil temp, and high water temp?
What inputs other than from the aldl diagnostic straight from the ecm would be needed?
Former Vendor
St. Jude Donor '13
• 8 analog channels (Temperatures, Pressures, Potentiometers, Lambda probe, custom sensors)
• 6 configurable alarm leds
• 10 configurable shift lights
• 1 RPM channel
• 1 speed channel
• Engaged gear visualization
• CAN/RS232 Protocol for ECU interface
• 128kb internal memory
• CAN protocol for communication with external expansion modules
• Connectors: 2 AMP + 2 Binder
The dash alone does not data log would need the Evo4 data logger for data logging
Former Vendor
St. Jude Donor '13
The MXL Dashes Series of dashes work with the following Corvette ECU
C6 LS2 2005 -> 2008 GM - C6_LS2
C6 LS3 2008 -> 2013 GM - C6_LS2
C6 Z06 LS7 2005 -> 2013 GM - Z06_LS7
C6 ZR1 LS9 2008 -> 2013 OBD_II - CANbus -
C7 Stingray 2014 -> OPEL - CAN
Using the included CAN/RS-232 connection, vehicle data can easily be accessed directly from a variety of OEM ECU
• 8 analog channels (Temperatures, Pressures, Potentiometers, Lambda probe, any custom sensors you want to install say AFR or EGT)
• 1 RPM channel
• 1 speed channel
So you can program the dash for what you want Oil Pressure, Temp, what ever up to 8
You have 1 RPM for RPM
You Have 1 Speed for MPH
You have 6 Alarms you can program
You have 10 Shift lights you can program
Depending on the dash you choose it may data log some are loggers and some are display only.
• 1 RPM channel
• 1 speed channel
Former Vendor
St. Jude Donor '13
Awesome, thanks for the help. I did end up finding something on their website that mentioned an Opel config after a lot of digging, but the clarification helps!
It looks like the Opel config has a ton of parameters, too. Pretty exciting! I'll see if I can give it a test run tonight.
