What wing setting for NCM? APR GTC300 on C5z
Jim
If you place a level parallel with the end plates you will be able to set at zero. Due to the design of this wing, I believe that still delivers a twelve degree angle of attack ( observe the outer portions of the wing or place a protractor on them.
I have also used a piece of square aluminum stock and set it down the middle of the wing, then used an angle finger to determine where the initial plane is.
I also have a GTC-300 on my Z06. Read this and all your questions will be answered;
http://aprperformance.com/racing-pro...ustable-wings/
Generally, somewhere between level and ten degrees is where you should be, although it all depends on your car set up
You should be measuring on a flat placed in the middle of the wing (last sentence of definitions on GTC-300 page).
Dog
Dog
