C6 Z06 Caliper Rebuild Kits - CF Sponsors?
I bought my Z a couple months ago. Last weekend I changed my pads / rotors and confirmed the car had probably been tracked more than prior owner led on.
The boots on the rear pistons were pretty rough and in the front - completely baked, cracked or gone @ 17k miles. The pistons still move well enough (kinda) but its obvious I need to rebuild or replace these things soon. I am just autocrossing and want to stay stock, so rebuilding is my best option.
Does anyone offer a COMPLETE rebuild kit? I am finding bits and pieces, but no complete rebuild kit with pistons & pins included. I want to strip them bare and replace everything. OR, buy a completely rebuilt set with mine as a core for +/- 5 or $600.
I found a rebuild kit on ebay that's close and cheap, but it's an ebay vendor... That's 50/50 at best and I can't trust that for brakes.
Supporting Vendor
In our experience they fit better and the rubber seals are the same.
This is mostly for Subaru Brembo's - but the aftermarket kits were often enough hard to install and sometimes messed up the pedal feel.
For a track car - worth it.
Piston's might not be serviceable from GM's standpoint but I think DRM makes them in SS which is an advantage on track anyway.
Received 8,964 Likes
The GM kits will come with small packages of lubricant to make it easier when installing the pistons past the new seals.
If you decide to spend some time cleaning the pistons you have a high probability of being able to get the deposits off them and be able to reuse them with new seals.
There are a few places that have just the seals. Zeckhausen Racing sells the front seal kit at a reasonable price. You might find it at a lower price but you will have to search. When replacing the seals make sure you order the lubricant for the seals. Zeckhausen has an 8 oz bottle of Centric lubricant. If you don't use the lubricant you can ruin the seals. The jerks behind the counter at auto parts stores will not know what you are talking about since they haven't sold caliper rebuild kits since before those kids were born. The lubricant isn't the same stuff you use on caliper slides.
Bill
