Thoughts on Michelin Pilot Super Sports.
any thoughts or anyone running the 295x18's all around? these would be on 18x10.5 rims on a base C6
NVM, found an thread where lots of people running that.
I ran them last year. They seem to work pretty well, I've seen -1.2g's in sweepers. They seem to like a little more pressure, I'm still experimenting. When pressurized new maximum (about 42psi), the heat and go away quickly. I've since learned to keep the pressures down to 35psi(hot) and that seems to help a lot.
First HPDE (NCM Park) on stock size Pilot Super Sports and I couldn't be happier with them. Camber is 1.5 front / 1.0 rear and pressure ranged from 37-40 psi. Tires inspired confidence and talked to me the entire time. Good grip from warm up lap to 10th lap. I could feel when the tires got hotter after a few hard laps in a row. The response went down a bit but the grip went up, especially in turns 18-20 near the sink hole. Only time the back end got away from me was when I swung wide on turn 10 and hit the water trailing across the track. Excellent turn in as well which led to a very balanced car. Everything stock with the Z51 package. I didn't check tread depth before and after, but there definitely isn't a noticable wear difference like with my pads and rotors. Would highly recommend these tires if you're looking for an all around street/autocross/light track tire.
Is the super sport or pilot sport ps2 a better tire (grip)? I am looking for the best street performance tires that may see occasional track use. Michelin seems to be the go to tire for the sizes I need (345/30-19 and 275/35-18). I am not opposed to using toyo r888. While I am interested in dry grip I want a tire that will work well in rain and not be dangerous in the wet.
First event May 2-3 at VIR with a 600mile round trip drive. I'll report back.
Thanks for the feedback. I noticed that going to a 325/30-19 opens up a lot more options. Is the Michelin still the preferred tire over Dunlop, Continental, Hankook, Bridgestone, Goodyear?
For possible occasional track use I'd stick with the PSS. The RE-11 is the only other tire I'd look at but only if you were going to track more often, they're pretty harsh on the street due to very stiff sidewalls.
As an informational followup to my previous post here's where we were on Saturday at the Tour. Due to disqualification of all C4-C7 Corvettes by SCCA National Staff (addressed in the NorCal Forum) I did not run on Sunday (as others did not) to provide complete results. But, I didn't find the PSS tires to be a disadvantage.
--Dan
2015 Crows Landing Championship Tour
April 17-19, 2015
**** UNOFFICIAL RESULTS (INFORMATIONAL ONLY) ****
PRONTO TIMING SYSTEM
Class standings for CAMS [13 Cars] (01:18:48 PM)
T 1 118 Scott Fraser 1966 Ford 427 Cobra Bridges
60.194 61.734(1) 60.126 60.126
T 2 7 Dan Bratten 2006 Chevrolet Corvette Micheli
63.380 61.869 61.101 61.101
(0.975)
T 3 132 Brian Hobaugh 2003 Chevrolet Corvette Falken
61.140 DNF 61.828 61.140
(0.039)
T 4 88 Richard Willhoff 2006 Chevrolet Corvette BFGoodr
62.046 61.951 61.323 61.323
(0.183)
5 77 Kenneth Mitchell 1989 Chevrolet Corvette BFGoodr
DNF 62.995 61.339 61.339
(0.016)
6 18 Bruce Cambern 1966 Ford 427 Cobra Bridges
DNF 61.734(1) 68.208(2) 61.734
(0.395)
7 3 Bryan Stewart 2004 Chevrolet Z06 Falken
DNF 62.549 61.840 61.840
(0.106)
8 89 sean breese 1989 Chevrolet Corvette Hoosier
63.533 DNF 64.972(1) 63.533
(1.693)
9 189 Tom Kubo 1989 Chevrolet Corvette Hoosier
DNF 64.664 63.873 63.873
(0.340)
10 32 Steve Hobaugh 2003 Chevrolet Corvette Falken
65.507 DNF 65.572(1) 65.507
(1.634)
11 49 Dave Thomas 2007 Chevrolet Corvette Toyo
DNF DNF 69.567 69.567
(4.060)
12 44 Rick Brunetti 1999 Chevrolet Corvette Falken
DNF DNF DNF No Time
13 55 Carrie Willhoff 2015 Chevrolet Corvette Micheli
DNF DNF DNF No Time
--Dan
April 17-19, 2015
(0.975)
(0.039)
(0.183)
(0.016)
(0.395)
(0.106)
(1.693)
(0.340)
(1.634)
(4.060)
DNF DNF DNF No Time
DNF DNF DNF No Time
IMO, the Michelin PSS is the best overall tire for recreational track use.
I have run almost every brand and compund available, including racing slicks and R comps, both sticker and scrubs.
The PSS will not match slicks and R comps for the first 6-8 heat cycles, if that is your goal. But the PSS will last at least 12 agressive track days, or 48 heat cycles.
The PSS grip is excellent, and I convinced another instructor at Mid Ohio last year. In the last turn before the straight, he screamed that my Z06 was going to break loose, but it didn't. He told me than he was unable to carry that much speed through the same corner with his Hoosier R6s.
After 16 track days, I was concerned that my PSS would get hard and start to "chunk" apart. I took my car to the Michelin tent at the grand opening of the NCM Motorsports Park last August, and their chief design engineer told me they were fine. I then proceeded to chord the fronts, but the the rears are still going strong.
If you are a recreational HPDE driver, even at the advanced level, the PSS is hands down the best bang for the buck.
I found them to be very good when new, but even then, I thought they went away very quickly when hot and pushing it fairly hard (compared to R6's anyway) - but having said that, at Streets of Willow, I was only a half sec or so off my R6 times when new ... pretty impressive, and to me better, a much better choice than the NTO5's I previously ran as street/track tire ....
What pressures are you running? I have ended up starting at 25 f/24 r, after experimenting a bit on the higher side (which didn't work for me at all, no grip), ending up around 34/33 hot ....
#33
Car is a 2015 C7 Z51 with Super Sport Tires.
The people at Spring Mountain have certainly tested what pressure / temp are best for these cars in the nevada desert. This day the air temp was about 77 F.
This data was collected via the on board PDR (performance data recorder) and Cosworth Toolbox for GM.
#34
pss is a wonderful street tire. grip is very consistent over the life and a full 4 year life should be easily do-able
the comment about best street/rec track tire is where i fall in opinion as well
tires are good in the cold, excellent in the wet, good in the dry and can handle moderate track time
one part that hasn't been touched on is how their "lack" of grip compared to slicks is actually a good thing for a stockish c5/6/7
the lack of grip prolongs drivetrain life, is easier on brakes and MUCH easier on the drivetrain and hubs. suspension will also feel correct. slicks on a stock car can often bring about the loveboat feeling and that's not even counting all the other cons regarding part life
#35
the big benefit of these is a bit more grip when hot and a bit more resistance to scrubbing
#36
#37
With Rivals, I have found my front pressures to consistently gain 7-9 lb (while the car was understeering badly and I was likely overdriving it). OTOH, with a more balanced car on RS3s, I still find a minimum of 7 lb pressure gain per session. Will be interesting to see what happens with the PSS tires.
#38
Having participated in 5 Autocross events with my C7 Z51 since last August, I have some definite thoughts on the PSS tires.
Now, I live in the Vancouver BC area, so WEATHER is very contributory.
In August, temperatures were about 18 deg C and sunny day, and the tires were AWESOME.
In September, temps were about 5 deg C and cloudy, and the tires were terrible. No grip at all.
In January this year, same conditions as last event, except also was rain, tires were terrible.
In Feb this year, about 10 deg C, cloudy, tires were adequate, but not great.
Last Saturday (April 18), temp was 18 deg C, nice and warm, tires were great. Good stick.
Yesterday, temp started at 7 deg C, standing water on track. Tires were terrible... no stick at all.
The day warmed up, had some sunshine and about 15 deg C in afternoon, and tires improved considerably.
Pavement got warm, and car set FTD (a PCA event).
So... my conclusion....
When the temps are nice and warm, these tires are GREAT.
When the temps are cold (below 10 deg C), they are not.
I have ordered Toyo R888s to replace them.
#39
For those of you who have experience running these tires aggressively on the road course what are your thoughts on alignment?
In my case the fronts will be much smaller than the rears (275/35-18 vs. 345/30-19) and the car has near stock C5 z06 horsepower. My current spring rates work well with hoosier R6 (295/315) so the front may be a bit over sprung for the super sports and the rear under sprung.
#40
I'd recommend running the alignment specs by Pfadt (link below). I'm running 1.5F (245 width) and 1.0R (285 width) and am very pleased with the bite and balance through corners. I've done about 10 autocross events with those tires/alignment and 1 track day at NCM. I've also put about 8,000 miles on the car and still have even tread wear.
http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf
