Oil, Tranny and Diff Coolers: LS6
We are building custom coolers for the above vital fluids for my pikes peak build.
There are a myriad of heat exchangers out there. Not point in buying one that does not have the capabilities we need. Any clue on what the minimum BTU rating should be? Or maybe size?
For the tranny and diff we will be running electric pump(s). Seems to be they range from $50 to "way too much". What does everyone recommend?
And what about the engine oil cooler? Does it already have a mechanical pump from the OEM? Or do we need to run an additional electric pump for that?
Lastly, the tranny and diff coolers will be mounted in the rear of the vehicle with limited air flow. Would it be necessary to put some small fans on them for them to do their job?
Thanks!
Jeremy Foley
Thanks!
Jeremy Foley
The reason everybody uses the way too much electric money pumps is they are really the only ones that will hold up to the hot oil temps they see. Looking at your avatar you have a C5 Z06, you can do what DRM does with their trans/diff coolers and mounts them in place of the rear brake cooling ducts (or you could buy their kit). You don't need a fans, you are taking advantage of the airflow that is already designed to go through the rear inlet.
For engine oil, you can get an adapter that runs off the oil filter block going to -AN lines. Several vendors sell them, DRM, Lingenfelter, etc. The stock pump should do you fine, but you might want to shim the oil pressure relief spring when adding the cooler in. What you do want to make sure of is that you have big enough lines and a good flowing cooler; most run -10AN. You don't wan to create a restriction in your oiling system by running a cooler and lines that can't keep up with flow. The other option is to run a radiator/EOC combo from DeWitts or Ron Davis. DeWitts sells a modified C6 supply line that works ion the C5 and includes the factory oil pressure bypass to keep oil moving in the engine and cooler.
Thanks for the tip on EOC. So are there no alternatives to the super expensive pumps?
P.S. This car will see normal track events too when completed. But the mountain is harder on cars than most people realize.
Yes, that is quite the system. I never asked Lou for one. Maybe he'll throw it in the pile
I went with the ron davis radiator from phoenix racing that has integrated engine and trans oil coolers (with a pump for the trans cooler located under the right rear quarter panel). According to phoenix, the trans cooler alone is sufficient to keep both the trans and diff cool. To be honest I haven't really tested it yet but that is what they run on their race cars so I figured it is good enough for me. Pricing was not bad for the whole system.
Makes sense with the thin air and whatnot.
My EOC is a kit from PCMforLess and my trans cooler is a kit from Doug Rippie Motorsports. Along with my DeWitts radiator, my ST2/ST3 car stays cool in all conditions... finally.
-Kevin
-Kevin
Don't reinvent the wheel and spend extra time and money. DRM makes complete kits for tranny, diff and engine oil cooling. They are race proven and from personal usage, I can say they work !
To be honest, I think the DRM package is a little over priced. And designed for people who want an easy solution. We have the capability of doing the fab work. Just need the right components
Here's a couple quality name brand oil cooler for you to use:
http://www.setrabusa.com/products/oi...ine/index.html
http://www.fluidyne.com/automobile-oil-coolers.html
If you look at the thumbnail pics of the trans and diff coolers installed on a car on the DRM website, it almost looks like that's the pump they use in the kit. You can see the last part of the sticker on the side of the pump says "...ton". The continuous operating temp on those pumps is a bit low for racing though.....hopefully their published max. temps have been de-rated a bit.
ETA: did they add a cooling port aimed at the input shaft when your trans was built? That tends to be the most beneficial are for cooling since the bearing there can starve for oil without it.
Former Vendor
We have had great luck with the electric pumps with the Viton seals. Last week I got a call from someone replacing one after 10 years and 20k track miles. That pump paid for itself. About 8 months ago we had one leak out of the box, the next day air sucked but it made in time for his event. That was the first time anything like that ever happened.
If you want a super nice electric pump look at the Weldons. They are a very nice setup. Pro racing stuff!!!!!
Randy
BTW I would cut that upper radiator neck off and turn it 180 degrees Then stick it back on
Randy
