Dewitts rad eoc line routing
Dewitts Radiator Left side EOC with Ligenfelter oil line adapter.
Are these oil lines installed correctly at adapter? 60 degree on left, 90 degree on right.
Oil out to lower connection of radiator? Oil in from upper connection of radiator?
I have the same setup except I made my own AN lines. Your arrangement of fittings looks to be about as good as it gets (I wound up using two 90 degree fittings because I liked the routing better)
Also If I remember correctly you are correct with your radiator connections, you want to feed the cooler from the bottom to prevent any air pockets.
Here's mine:
Here's mine:
I would use the 90 degree on the left and the 45 on the right, then you should be able get the hose/fitting on the right to over the other hose and tighter to the block.
